Academy P-40C
Hi all, i recently purchased a P-40-C Tomahawk made by ACADEMY. The model itself is not bad, goes together pretty well. The cockpit is sparse, but the instrument board is a piece of junk. It looks like someone put a piece of plastice there to fill out a space. any suggestions where i can get a replacement for the board. It is so bad, i would just as soon leave it out if i can’t find a replacement. Any help would be greatly appreciated. thanks doc bailey
Eduard makes an interior PE set for this kit. It will solve your problem for about $7.00. May be hard to find though since it’s an older releases.
Regards, Rick
Found this:
http://store.spruebrothers.com/148-true-details-p-40b-p-40c-warhawk-cockpit-set-acahob-kit-49003-p3418.aspx
and this:
http://www.greatmodels.com/~smartcart/cgi/display.cgi?item_num=EDUFE137
you guys are great !!! thanks for the quick response. i checked on the sites you gave me an placed my order for the eduards kit. again, thank you. doc bailey
