academy F-15E 1/48
anyoe built it?
Hi curt.
I’ve built it several years ago (around 1992). In fact it was the first model I ever entered in a contest. From what I remember of the build, the kit went together well with some fit problems around the intakes. The cockpit was detailed nicely (considering my limited detail knowledge of the F-15E at that time). If accuracy is really high on your list then you’ll need to replace the conformal bomb racks with correct resin sets. Those may be hard to find as I believe that the resin set is no longer produced.
Chris
