Academy 1/72 F4F-4 Wildcat by a plane newbie.
Hello everyone here in the aircraft section. I picked up an Academy 1/72 F4F-4 plane, simply because it was the cheapest WWII plane avalable at the online store. Costing 2,5£, roughly $5, and moulded in 1987 I didn’t expect good quality. but wow, it was way better than I tought, and I had no problem with the fit either. However the pilot was poor so I didn’t have him, and theres no cockpit. just a simpleseat with a joystick. the engine was also nice, but not “real”. Well, it was a fun build and I will be building more planes from now on! Also, I build this for the Junior GB.
So as my first plane, I need constructive comments to improve on further builds. [:D]
Thanks,
-Huxy
Huxy- Well done, great to see you here! For your first aircraft, this is a beauty. As for constructive comments, here’s what I would suggest:
Tone down the panel wash a bit and possibly use a dark grey as opposed to straight black, looks a bit stark
After decalling, use a sharp blade and gently cut the decals along the panel lines and put a little bit of decal solvent into the panel lines to pull the decals into them
Weathering may be a bit on the harsh side, but that’s a matter of personal preferences. Sometimes less is more
On the gun stains, try using ground up pastels and lightly brush them on to gradually build up the effect
I hope that helps! Looks like you are well on your way! I look forward to seeing more of your work. [tup]
Nice job there. [tup]
In addition to Frank’s excellent suggestions I’ll add that you have to remember that the markings were painted on in real life, they weren’t “stuck on”. So your panel line washes should really include the panel lines that the markings cross, instead of going around them.
She looks very good! I bet some of those Wildcats on Guadalcanal looked just about like that in the conditions at that place. I built one of these Academey F4Fs myself several months ago, and like you I am still learning. I didn’t weather it too much, but I did the following to it and I think it looks ok. If your interested it’s here:
/forums/863442/ShowPost.aspx
I should mention I use acrylics becasue they are easy to clean and don’t have the strong odor of enamels. After spraying the blue and light gray colors using the airbrush, I let it dry overnight and sprayed Future floor polish over it to make a nice surface for the decals. In some cases, you can omit the Future spray and just brush future over your decal with a brush. It works ok for me, but you don’t have much time to place it as the future starts to dry quickly.
Let dry several hours and then add your weathering. Lightly is best, and as was stated earlier, less is better. I did my panel lines using a mechanical pencil and ran it along the recessed panel lines. I didn’t press hard, just enough that the pencil line was visible. You can carefully erase if you make a mistake (the model is even more protected if you spray Future over all of it, so in most cases a Futrue spray is an advantage). Make sure you carefully slice through the decals with a sharp blade along panel lines or other recessed areas first though. The pencil is pretty unforgiving if it hits a decal not completely recessed, and it can really tear it up.
You can the shave a pastel stick into a fine powder with a blunt knife, and collect the powder in a small cup (soda bottle caps are great). I swirl into this a cotton swab and carefully and lightly run it over areas of the plane that are to be stained (behind engine, guns, exhaust vents, etc.). But try it on some scrap plastic the first time; you may have to rub the swab a few times on something before actually applying the pastel on the plan (it may be too dark initially). You can even give a light swab on some of the panel lines you want to further accentuate. Try it and see what you prefer.
After a few hours, when the weathering is done, you really need to spray with a dull or semi-dull coat. This does several things: it protects your pastel application, seals the decals, protects the entire paint job, and finally gives the model a more realistic appearance where the decals look painted on and the weathering is enhanced (the pencil application is a bit shiny, and this must be dealt with, or everything looks off). After all this, I add the final small pieces that otherwise may get broken (antennas, etc.)
A lot of people here do a much better job at modeling than myself, and their work looks fantastic. I’m working on getting to that level. But these steps work for me. Most builders also prefer to use a different process to enhance the panel lines (I believe adding a bit of thinner to the pastel dust until it is well wetted and then they let it run into the panel lines by capillary action. They then wipe off the excess, leaving the panel line enhanced. Some prefer darkened, well-defined panel lines, while others do a very light application. However, if you do this, you must spray the whole model with Future so the paint job is well protected from the continual applying and cleaning).
Hope this helps!
Thanks everyone. Might look into setting the decals along the panellines tomorrow… if not even tonight…
And thanks for that long post, Hogan. Learned alot there, and sure, your plane looks way better :slight_smile:
Concentrate on the fundamentals. If an artist paints on a cavas full of holes, no matter how well his painting skills are…it still looks like a painting on a canvas full of holes.
Some suggested areas to improve on:
Master the model before you try the painting. Build a model without any paint, it is a great exercise to develop your skills…you can’t hide your mistakes so you learn how not to make any.
You’re off to a great start, keep going!
I agree with all said so far but most with what Gerald has told you. After the basic, everything else will come along. A good thing to take a look at is the IPMS web site. Go to the link below and click on “competition handbook.” It will tell you what a judge will be looking for as far modeling basics for each category.
When you get all those down pat you can worry about weathering. And as you go when you have a question about one of those specific items, pop in here and ask away. But be prepared to read since we all just LOVE to talk ‘round here.
http://www.ipmsusa.org/MemberServices/memberservices.htm
Thanks HawkeyeHobbies and Wingnut.
And nice “handbook”, wingnut. Learned a bit. Will be reading more on it :slight_smile:
Also take a peek at this thread. I refer a lot to it. One of these days I will redo it here or on my website.
I think it is pretty darn good. By no means am I knocking anyones advice here but what I see is that you are trying different things and experimenting and that is how you really find out what works for you so great job! That being said I am a firm believer that no one knows everything and the advice and resources here are invaluable! Try to get better everytime I do but am not always sucessful.
