About Ford engine blue
Some of you have build some Mustang, I guess… So I ask you, how you painted the engine blocks? I think there is Ford engine blue available, from Model Master, but it is a little difficult to obtain here in my country, so I’d like to know if you used a mix or if you used a military color that is close to the engine blue. I have Monogram’s '70 Boss 302 Mustang. Thanks a lot in advance. Best regards.
José.
Can you get Testor’s regular line of square bottle paints? If you can, the blue bottle dark blue #1111. If you like, you can add a few drops of Testor’s white until it matches the pictures on the side of the box.
I think this is a better blue than model master’s Ford Engine Blue. At least it look closer to the real thing for me! Good Luck amigo!
OK, I’ll give it a try… Thanks a lot. Best regards.
José.
