A Paint color question...
What color is the Interior gray green in the Model Masters enamels? or close.
Or what colors could I mix to make that one?
MM makes RAF Interior green is that is the grey green you are referring to. Not sure the number on it though. you should be able to pick it up online if not at a hobby shop. I just bought the entire RAF set from MM (greatmodels.com) and it was a lot easier. Has the major exterior colors of all theaters and the interior green. All in one box!
Thanks alot Tom, I have WEM’s Color Coat of RLM 02 and it matches perfectly !
FYI
Pat
