I was looking for somthing to apply putty with and chose a plastic shirt collar stay. These are the long, flexible and very thin plastic tabs that keep shirt collars straight (stays can also be brass or silver - don’t use these). On better shirts, they come out and are replaceable. If you don’t want to remove them, I believe they can be bought at fabric stores in many sizes. A cheap, disposable and easy solution.
Good tip! Thanks
Gip Winecoff
Thanks! [tup]
Hey thanks! I’ve realized that using a disposable razor blade for applying squadron putty also works, but thanks!
The coffee stirrers at McDonalds are great for putty and mixing paint
You can allways get some good advice in this forum. [tup]
Thank you guys, have to try it.
