This is the 1/72 Pavla kit of the UT-1, which was one of Yakovlev’s designs before he headed his own OKB. It was a sport plane, and shortly evolved in to a 2 seat trainer and that airplane trained a large number of the USSR’s WW II pilots. You can see the similarity of the planform to the Yak-1 and its progeny. The airplane with it is of the same era and also 1/72, the ANT-25 from the UKAR kit. The span of the UT-1 is a shade under 4 inches. Except for the stars and the bort? numbers the markings are painted on. Comments/critiques are welcome.
Awesome job! Super clean looking planes. That UT surely had to be a challenge.
Fantastic…simply fantastic! excellent paint job, how was it to mask the cowling and stripe?
Wow! That’s damm cool, John! …and tiny! Very nice work all around. The hand-painting looks really good! You always come up with some of the most interesting and unusual subjects here. I always look forward to seeing what’s next off your workbench! [tup]
…and even though I know next to nothing about Soviet aircraft, I had a feeling I’d seen that shape somewhere before. [;)]
I love the vibrant colors and unique subjects, John. Nicley executed!
Thanks for the nice comments, once again you are all too kind! I have liked the UT-1’s lines since I came across it some years ago. I plan to do an RC model of it and will probably publish the plans. I was able to get extensive drawings of the airplane from Yakovlev last year.
It wasn’t difficult to paint the nose cowl and engine as they were separate resin parts. The fuselage was masked with Tamiya tape cut in strips about 1 or 2mm wide except for the scallop shapes at the front, which I did by cutting ellipses from the Tamiya tape using an old drafting template. These were put on first and the the straight lines were taped over them, helped with alignment. I did the side stripes as one run to keep them straight, and then placed a star shape over the where the stars go to make the break with the correct angles. Some of the detail on the wheel fairings was freehand painted and won’t stand up to a close up photo, but it looks good in the display case. These new digital cameras do have their down side! The kit has a nice resin cockpit but the opening is so small I can’t get a photo of it.
Beautiful work, John, and the juxtaposition of the two a/c is great! Is the big bird the same one that Chakolov flew from Russia to Vancouver, WA in the 20’s? Thanks for sharing!
Brian [C):-)]
Yes, Brian, it’s the ANT-25. Thanks.
Very nice pair of planes, I must say! I’ve always been really drawn to the ANT-25. I like those high-altitue, long range jobs with the enormous wingspans anyway, and the ANT-25 adds to that with its unique Russian… I don’t know, “ruggedness”. A bit less refined looking? Whatever the case, I think they both look AWESOME!!
Hi John,
Wow, those are some pretty, small, jewells in your collection [tup] …and a nice break from the typical!
Beautiful work, thanks! [:)]
Take care,
Frank
Hey nice John. I just saw the ANT 25 on a TV show about Russian a/c a few weeks ago. had never heard of it 'til then.
