I’m sure he just place it on that board to take pictures…I’m thinking it looks pretty good! Camo is well done, figures look nice and the extra details add to your build. The cleaning rods are suppose to be blackish, but that’s an easy fix!
Oh, back to the thread. I agree that although the photography is bad, there are some good things about the build. A few things I would add is I doubt live rounds would be left lying on the back deck in any situation. The tank is buttoned up with para’s casually lounging on the deck?
Just doesn’t work for me, but , hey, it’s just an opinion, if your happy with it, it’s all good. Like the man said, “never mind the critics”.[#wstupid]
Thanks for the input, I will change the rods to black. As far as the rounds on the back, I wanted to Us empty shells but the kit only came with three live ones. The camo was done using Model Master enamles using an airbrush. here are some better Pics
Just a thought on the rounds (if they are still loose and not glued down), if you want to show them as spent cases, you could cut off the shell portion and then drill out the necks of the casings to achieve the desired effect.
