OK, I know you guys have probably answered a zillion questions on this subject…please bear in mind I have only just discovered this stuff and its all very new to me.[:I]
OK, I am going to dip my canopies in this stuff and what I’d like to know is can I spray enamel paint on top on this stuff without causing any damaged to the Future coat? Or do I need to use acrylics here?
Thank-you![;)]
Once the future has dried/cured you can just paint away, enamels, oils, acrylics… it all works.
my advice, and ive done a bunch of future dipping, and this is supported by others who have had similar experience as me:
let the future dry for a week. Dont be tempted to do your final coats right away, let it completely cure out, especially if you are going to use any solvent based stuff over the top (lacquer etc).
Good luck~
David
Scott, David, many thanks for pointing me in the right direction[tup] Knowing that I can use my enamels on this stuff is great news! [:)]
