Hi Guys and Gals.
Started cleanup on a 1/6 Morrigan kit. In the pics you can see some of the problem areas on 2 of the 4 wings, most don’t show up on the pics.
(Sorry, for the poor quality, haven’t had time to iron the cloth or do a proper setup)
Rest of the kit is in a similar state with a 2mm gap between one arm-shoulder joint (being the worst), plus the attachment points for both main wings need to be reworked totally. Plenty of sanding, puttying, sculpting and smoothing out to do, reckon 4~6 months on cleanup alone. [B)]
Pose is as follows, she is siting cross-legged with one arm drapped across her knees. Going to be fun painting her prior to assembly.
Oooh, you don’t know what the char looks like you say?? See below:
This should give you an idea, the bats are not marked on the kit and will need to be stenciled in.
FYI, this is NOT a recast but the first kit the sculptor/caster released about 8yrs ago. Pretty much standard quality for a home-produced garage-kit.
