67' Dodge Coronet R/T with working headlights!
Me again…Here’s my 67’ Dodge Coronet R/T. Although you can’t see it in the pics due to my camera’s intense flash, this model has working headlights! I was feeling ambitious one day so I took a trip down to my local surplus store. I bought two small white LED’s, some wire, a small switch, a battery terminal and a battery. To tell you the truth, I can’t remember what kind of battery I used. anyhoo, I drilled out the headlight buckets and mounted the LED’s with some two part epoxy. I borrowed a soldering iron from work and attatched the wires, running them along the inside pannels to the trunk. The switch was mounted back there as well, it is barley visable in the chasis, its between the rear frame rail and the inner quarter pannel…stealthy! The battery mount was than mounted and everthing was soldered. It turned out so great, it surprised the heck out of alot of people at the model show in London Ontario…didn’t win anything with it though. It’s actually quite brite, you could use the thing as a flash light in a pinch.
I didn’t use as many aftermarket parts on this one, just the tail pipes, bare metal foil for the chrome and rad hose using wire and heat shrink with aftermarket attatchments. I fabbed up a dip-stick using fine guage wire and also added an antenna. If anyone has any questions on how to attempt this headlight jazz, don’t hesitate to ask. Stay tuned!
Outstanding, [^][yeah] [tup] I bet those “Russel” ends are a bear to put on the Rad hoses…I could not imagine even trying that. And the windshield washer fluid is really cool… Thanks for sharing…now off to go check out the 32 …
Actually, its not hard at all. The trick is finding the right guage of wire to use in combination with the heat shrink. If the right combination is used, you don’t even need glue, they’ll press fit together…give her a try sometime, you will not be dissapointed.
What is a pain, is using the metal braided covering, which I used on my 70 Road runner pro-street…thread comming shortly.
I can’t beleive you didn’t win something. Very nice build!!!
Thanks for the complements!
