is this putty alright to use on plastic (styrene)? if so what is the pros and cons on using this putty?
any and all info on this would be greatly appreciated
Well i think mainly used for marine pupases but found this
Designed specifically for the fiberglass boat repair market. Recommended for filling pinholes, scratches and other surface defects on hulls. Its white color minimizes the possibility of color showing through the final coat as can happen when using colored putties beneath white paint. Other advantages include easy sanding, fast drying, spreads easily, and has low shrinkage.
