I want to scratchbuild an accurate 2A46M-5 tank gun for a T-90A, but I need two measures: diametre of the gun barrel (the part shrouded in the thermal sleeve, I don’t care so much about the muzzle, it can be estimated)) and the diametre and length of the bore evacuator… I think these measures can be taken of the Tamiya T-72 gun or an Eduard replacement barrel, the 2A46M-5 gun is a little longer (125 mm/L55), but I don’t think it is thicker. Thanks a lot in advance. Most regards.
Well, still don’t know the answer, but I’ve just posted this message yesterday and it has been sent so the Page 2… I won’t allow this until it is answered, I think there is someone out there who can tell me, and there is more posibilities for my message to be answered if it is in Page 1, dont you think?.. Still waiting for your input. Thanks in advance. Most regards.
José
Tamiya’s gun on their T72M1 is tapered from the mantlet cover to a distance of 16mm. Outside diameter at mantlet cover is 6.5 mm, at 16 mm outside diameter is 5.5mm. Bore evacuator outside diameter is 7mm, length not counting collars is 21.5 mm. Measurments include thermal shroud.
Case closed… Thanks a lot for the measures, I think It can be scratchbuild. Most regards.
José
