This is a 1/72 FineMolds G-10 kit, backdated to represent the earlier G-6 with improved DB 605 AS engine and larger super charger.
“Schwarze 27” was from 2./JG 3 during the spring of 1944. The unit began receiving these upgraded Gustavs in May, their role being to intercept Allied escorts.
OUTSTANDING JOB, Jack!! I thought the photos were all in Black & White until I noticed the yellow triangles next to the cockpit. Interesting paint scheme. I like it!!
Beautiful build Jack! I had just stumbled upon this scheme and roll recently for the G-6 AS. You nailed it here!
I have been pondering a similar project. Now perhaps can tell me, from the outside visually, what are the differences between a G-6 AS like yours and a G-10? I can not for the life of me tell any visual difference in the two types.
The oxygen mask was just some putty added to a resin pilot from PJ productons:
First the easy question (though it wasn’t easy to do), the spiral was spray masked, using a combination of thin strips of Tamiya tape and liquid mask. I still had to touch up with paint brush afterwards, as well as rely on the brush to get the curve at the very tip of the nose.
For the differences compared to the G-10, there are a lot of minor details only apparent when comparing line drawings. The two main ones would be the short leg tail wheel and shallow oil rad intake on the G-6. Other details addressed on the FineMolds kit:
rudder should have curve to the bottom corner
oil access cover on port side nose is lower
access cover on starboard engine side is lower
add vent louver on starboard side below foward cockpit window
eliminate access cover on rear starboard fuselage
no antenna on wing underside
eliminate pair of bulges on underside of engine
There was no way I was going to attempt to scribe in new access covers in 1/72 scale, so I just made the details out of clear decals. The red cirlced ones are the neccessary ones, while green are just to improve detail or added due to loss from sanding the fuselage seams.
Thank you for the information Jack. It does not look like too much a effort to backdate a G-10 to a G-6/AS. But I’ll leave my G-10 as is since I found a similar scheme for one. I do like that overall 76 scheme, and they are not common at all.
No probs, Stik. Only reason I went for the G-6 backdate was for the cool look of the black fuselage codes. The G-10 seem to carry white ones when using the 76 overall scheme.
