1000 years III reich GB
Hm I am going to be cutting up some 1/35 Tamiya modern US soldiers, since there not good for much else. So put my down for one modern Wehrmacht German in WWII camo.
So when is the start date for the build?
when you want to start it. i think the final date will be… 12/06/07, it can be.
modify its name, put something like “KriegsFalke” or something like that.
Cool I will start on them today then, pictures later on.
you could put one of the soldiers with an MG 42 if there is someone in position and/or if you have a 1/35 mg 42 avaible.
I’ve been watching this thread too. We’ll see if I have the time to do it. I would like to, but I also have an idea for a group build I will throw out after my current group build, and possibly this one. I’ll be a maybe.
right man. i hope you can enter.
Sounds good, but how about “Sturmfalke” (assault hawk) for the Blackhawk and “Schutzfalke” (protection hawk) for the Pavehawk. So mine would be two “Schutzfalke”.
One of the marines is a machinegunner so the M42 would be perfect.
Think I will do that since I have loads of MG 42, I think I will do three figures since the 4th one I need for other conversion.
Avus I was thinking the same thing about the guy with the machine gun also.
right. it sounds very nice.
I’m probably going to try to put the name “Stuka Zwei” on the aircraft and make it a modern Kanonvogel Stuka setup.I just wish I had more kits to toss in I love what if scenario building it’s a lil more fun in that you get to use your imagination a bit more
so, i change the name?
Nope “Stuka Zwei” is just going to be a personal insignia below the cockpit rim something the pilot named his aircraft it means “Stuka II” and the Kanonvogel setup is a weapons configuration used on WWII stukas for tank hunting with 37mm cannon pods under the wings I have a few gunpods from Hasegawa weapons sets lying around and thought I would use a couple[:D]
right, i know what means kanonenvogel.
Hey Sturzkampf would it be alright if I add other build? I have a Tamiya 1/35 M113 Fire Support Vehicle that I would like to convert to a Sdkfz-300 Ausf.U Assault APC.
Got the figures built pics
Helmets are Tamiya, gear is Dragon. The Stug 44 are Dragon and the MG 42 and Panzerfaust are Tamiya.
Tempting idea, in fact a while ago, due to the “What If A-10 GB” I had already played with the idea of building a hog in LW colors, didn’t do it than because it wasn’t allowed.
But now you bring this GB on, and I must repeat myself… very very tempting, however I will have to ask my fuhrer first…
I will throw my hat into the ring here. I may do a F-111 (have two spares sitting in the hanger to be built). Tempted to do my favorite, the F-15. Need to work up the courage on that one…
See if your ‘fuhrer’ would let you do some ‘experimental’ design work [;)] with the agreement that you watch the “youth” [;)] for an entire Saturday… Maybe if you can promise little outlay from the ‘state funds’ you can get the green light. [:D]
LOL the kit I’m using is one of the “Spare” kits i had for the same build [:D]
