So far, this kit is alright…on the outside. The inside is severely lacking in detail. Eduard PE and some fine wires help out up front, but there is nothing for the cabin area, other than the floor.
Got the office finished up…not sure yet, exactly what route I’m going to go for the rear.
I’d like to see what you are going to do with the cargo bay - I plan to built an “A” some day and closed ramp somehow doesn’t look quite right for Vietnam.
Since the rear is complete divoid of detail…one option was to scratch the soundproof padding and seats…for an empty cabin. None of which is overly difficult…until it comes time to close the halves around the floor and NOT break things.
I’ll still be doing a lot of work…scratching the detail toward the front of the cabin…padding, crew chiefs seats, and various details. I’ll also scratch up the detail toward the rear of the cabin AND the passenger seats will also have to be scratched, but will be folded up in the stowed position. I’ll load some crates inside, which not only depicts the majority of the missions this was used for (haulin beans and bullets), but also serves to hide the lack of detail in the center section. Will also save me a lot of bad words!!!
Started the padding by scoring thin plastic sheet…I did not like it.
[hmm] [hmm]
I remembered some PE mesh that I have…some aluminum foil, burnished down over the mesh with a q-tip did the trick!!!
The pattern looks pretty good to me. It’s not particularly accurate in its application, but looks better than what the kit gives! For what little will be seen, I think this will “pass”.
Agreed, and the wrinkles help the effect. Nice little trick. Will look great when painted and weathered.
Did the same with making diamond plate corner protectors on a Jeep CJ build many years ago, using the wrecker bed floor on the old Revell Midnight Cowboy kit.
Added some detail to the rear section of the cabin…with some “artistic license”…
Tamiya tape and brass rod for the seats…
Painted and in place…
I used this pic for inspiration…
I used some cardboard (what looks more like cardboard…than cardboard!!!) from an old Eduard kit box…folded and used a fine razor saw to cut in the individual boxes. Scratched the pallets with cut strips of thin plastic…
Also had to scratch the crew chiefs jump seat…
Closed up and finished up the detail for the ramp area…
All these details are loosely based on actual events…but not a true story!!!
I used clear packing tape, cut into thin strips(obviously!), for the banding on the individual boxes. Tamiya tape, painted dark grey, to band them together and to the pallet. Also Tamiya tape for the tie down straps. I drilled holes in the floor to pull the tie downs through, CAed to the bottom…we’re pretending the ratchet is on the other side…that can’t be seen!
Stunning job on thjose seats, those have come out perfetc. And i do like that palletized loads. I used to look forwardto going out in the back of a Chinook to drop those out in the desert. Bloody dicey but great fun.
Looking at the “black box-like things” one the fuse/tail sides, and the angled “thing” between the last two windows.
What are those (technical name)?
The kit does not include them, so I’ll either have to find resin a/m, or find a close up, detailed pic so I can scratch em(helps, if I know what I’m looking for…beyond “those thingies on the back of a chinook!”.
The three plates at the rear are Chaff/Flare launcher mounts as part of the Missile Counter Measures system. The actual launcher boxes are not attached in your pic. You can see them in the below pics where the mounts are in your photo.
Also note that these are CH-47F models that come in this new color, which is FS34201, Woodland Desert Sage. CH-47Ds are still painted in FS34031, US Army Helo Drab.
I ordered the “dust bin” intake filters through Shapeways. I like em…they’re a bit rough, due to the process, but look the part. There is a part of some sort, that comes out of the bottom/front of the center pylon and into the filters. The kit intakes had this molded to them…the a/m filters had a slot, to accommodate said item. I cut and carved the part from the kit parts…
On to the paint booth.
Black and white to start with…
Then I went with a lightened (with OD) US Helo Drab overall…fairly thin, allowing the blotchiness of the blk/wht to show through. Then hit some areas with straight Helo Drab…then some more areas with a little grey mixed in. It will get some more colors after the decals go on…gotta weather them too!
I finally got the decals, with a little help from some friends.
Back on the bench…finally!!!
Stopped by my airport the other day, to bid a job…just happened to be a Chinook on the ramp…got some decent detail shots for the locations of the flare dispenser mounts. Scratched those up with sheet styrene…also made new pitot tubes with aluminum tubing.
