Here’s my third completion this year. It’s built from the RoG Black Thunder Tornado kit using the kit decals for a plane that was stationed at Holloman AFB. Don’t know how accurate this would be but I built her as a tired and dirty bird ready for the trip home. It’s basically OOB but I built a blanking plate for the intakes(since none was included) and copied the fans from another kit. Not too noticeable in this scale but you can see them at the right angle. The pivot points for the wing pylons would have never survived the build so I snipped them off and drilled the pylons, punched some discs to go inside the wings and inserted some straight pins to mount the pylons to. The pivots for the stabilators were flimsy too so I snipped them, drilled for some brass rod and put a piece of aluminum tubing through the fuselage. I completely screwed up the wing and fuselage walk decals and figured I’d never mask them to paint so I left them off. Unfortunately, the stabilator outlines were already on. Paints are MM Acryll and the camo was done freehand. I also used MM Acryll flat as the final coat and thought it turned out a little white. This was built for the Swing Wing Group Build hosted by Pordoi. If you want to see any of the progress pics that’s where you’ll find them.
Comments and critiques are welcome. Thanks for looking.
Tony
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/162.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/163.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/164.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/165.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/166.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/167.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/168.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/169.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/170.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/171.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/173.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/174.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/175.jpg)
!(http://i958.photobucket.com/albums/ae64/Wingman_2010/RoG Lizard Scheme Tornado/178.jpg)
