1/72 medieval ship by zvezda
hull together unpainted
bit worried by this , in the instructions , the half moon shape for the mast is the other way round .
painted some of the wooden interior
Steve,
I did that kit about 8 months ago, check my build for some pointers, the kits needs a little help.
would you be able to send me a link please , as I don’t know how to find your page bigjake
Updates on Zvezda Hansa Kogge - Modeling Subjects / Ships - Finescale Modeler Forum
my Facebook page name is Jacob B Groby III, if you are on FB, shoot me a message and I can drop a ton of pics,
thanks for that jake .
the hull painted not weathered .
I did some more weathering on the deck , hopefully I didn’t overdo it .
some bits painted .
found some deadeyes in my spares bin that are close .
bogged up some ejector pin marks
looks like some more bog work .
and the rudder
these decks fit really tight , no glue .
made some rings for the hatch
Replacing the deadeyes make a big improvement to the kit.
cheers jake .
I gave the hull a light wash
added some 2mm brass rod to the mast
the aft and forecastles going together
the forecastle did not want to go together , in the foreground you can see how much I had to take off . and I still have to putty .
jake , I found a lot of stuff on ebay , people , crates , fruit sacks etc , but this is aust , it wont get here for a fair while unfortunately . I’ll still put them on .the life boat was between $60 - $80 aust so that wasn’t happening , in the spares box , I a small boat painted up should look alright .
the aft castle legs were too short , so added some styrene and brass rod .
bit of paint should be good .
look what I woke up to this morning , how in the heavens , going to fill it with C.A. see what happens.
added black CA
after paint , quite happy with it
You can’t even tell it was cracked - how did that even happen.
I wish l knew jake , l just hope it holds together .
the anchor going on .
trying to remember how I used to make sails , been a while , found this old box , don’t know where it came from , :blush: cut a hole , mixed up white glue , paint and water , painted it , now waiting for it to dry ,
sail cut to size , trimmed , cord glued around the edges , and wire at the top .
Really like the plain bleached wood look.
cheers jake .
and the rigging starts .
