I can’t comment on the Zevzda as I only built the hobbyboss, but for me the level of detail is quite enough and there certainly it “enough” kit to build!
I am still waiting for my decals before I can complete it. Alteast I have built up the rotor assembly ready for paint.
I use a little trick I learned a while back. Try using extra hot water (NOT BOILING, MAY MELT PLASTIC OR DEFORM IT). Use a container that will hold the heat of the water for a while. soak parts in the water until it changes the flexibility of the plastic. When you think they will bend, support blades against an object with correct height you want. Put a bow in the blades and put some weight in the middle of blades to hold the same bend for all blades involved, let cool. Try using of old parts of an older model so you can practice the procedure. I get good results using this method. good luck…ric
Assuming you live in SA - where is that Hind A? I live in the Free State but am often in Pta/Jhb - would love to see that as I’m busy with a Hasegawa Hind A.
