Needed a break from the current project, so I pulled out HobbyBoss’ “Easy Assembly” LA-5. Very basic…perfect for a one day “power build”!
I started around 2pm, this afternoon. Even with a couple hours away from the bench, and another hour+ spent messing with airbrush problems, I still managed to finish it up before midnight!
She aint no show stopper, but will look okay toward the back of the shelf!
I spent maybe a total of 5 hours on it…I think that might even be a bit generous. Over the course of ten hours…I also did some work on a ship…and some other stuff, plus the down time I already mentioned. Old school…just build it!!!
Model Master enamels? Wow I thought you had to wait overnight or couple of days between coats of paint…How long did you allow it to dry before spraying the next colors?
Seriously…with this one (and most, for that matter)…I’ll hold it by a wingtip…I’ll spray the other wing first, then the rest. By the time the rest is finished, that other wing is dry enough to the touch, that I can hold it and spray the other wing. I did all black first, then did a basic flush/clean of the a/b. Gave it about ten minutes, then did some white “marbling”. Went right to the light blue belly. I let that sit about 20mins, because it would be masked. I freehanded the top camo, so I really didn’t wait between colors.
I spray in fairly thin/light coats, puting down very little paint with each pass. Dries much faster that way. I do give a little more time between paint and clear coats, and a fair amount of time before doing the decals.
