Believe it or not, I have been keeping busy with my 1/72 Vacuform H-4 Flying Boat (I’ve decided to refrain from calling it the “Spruce Goose”! Unfortunately, it seems most people don’t know it by it’s real designation). It’s just that most of the work had been freeing the fuselage halves from their backing sheets. (I’ve had about 12 feet of seams to get rid of! [:O]) Finally, though, I’ve gotten them to acceptable shapes, and have been able to begin fuselage corrections.
First off- the canopy/flight deck roof. The molded in roof has two problems- it’s way too rounded, and the sides slope way too much. So this is where I start.
I’ve started by getting rid of the kit roof (scored and snapped off with a razor blade) and adding a tab to mount the new roof.
Here’s half of the new roof. Checking reference pictures, I may have the wall a bit too straight, but it can be fixed if need be.
Here’s the roof fitted, with fuselage halves taped together.
Here you can see the difference between the kit roof and the new roof. The front piece was left of as a reference point, and has since been removed.
My biggest obstacle right now is getting enough internal support, while keeping it accepable for viewing after I complete the interior flight deck (as soon as I get a contour guage). Also, filling the gap between fuselage and new roof (while keeping the inside look good- for BOTH halves) will be an experience. But, an experiece for later.
Thanks for checking out my progress. It’s going pretty smoothly now, but give it time. [;)] There’s a looooong way to go!
[:D][tup]
(Any comments, criticims, or suggestions at this point, good or bad, are welcome)
