lol. I’m fine guys! Just had my upper teeth taken out because I DID NOT take care of them. They were causing my problems so I’m having them replaced. I’m just on the IB 800’s now so no odd effects with fuzzy memory now lol.
And no, that didn’t effect my judgement on the weld seams on a 1/72 model lol!!
It was more of a personal challenge to see if I can do it and I’m happy with these results, so yeah, welds on a 1/72! He,he,he,he,he!
I carried on with the welds onto the hull as well. They look really cool and they hide the glue seams like a champ. I’m not sure about the accuracy of where they are located, but they look really good.
Even added some to the back hull just for visual interest.
I removed and replaced the angled plates on the front hull sides. Dragon has also reversed these as well and molded them backwards, which works well for adding the correct detail in the end.
I’ve got the tracks on now as well. I wanted to paint all of those wheel assemblies first, but I don’t trust those dang DS tracks to stick to anything but a clean surface. So I’ll try using a wash “bath” to get some dark color deep in there later and see if that will get me to where I want to be concerning the unpainted deep recesses in there.
I still have some more pieces to put on there, but it’s shaping up very nicely!
That’s how far I’ve gotten on this project. 1/72 moves a lot farther than 1/35 even when adding details and modifications. But this is a pretty simple build. The only issue I’ve had so far has been the suspension. There are way too many sprue connections and they are not so simple to remove as they should have been because they are thick.
Dragon engineered these into two simple parts for easy assembly, but neglected to let you know that it will take you at least 45 minutes per side to just clean up the parts correctly.
So far its a great kit and easy to modify into a beautiful replica of a Mk III. Of course there are mistakes due to the manufacturing process and Dragon’s use of previously made kits of a later mark to make an earlier model. I don’t blame them for doing so and it still makes a good model without any modifications.
I’d like to see them make a Mk I or II to add to this line, since they were also present in the Dieppe Raid.
Anyways, I’m happy with these results and I’d recommend this kit without reservation.
Have a great day and Happy Modellling!!
