OK one and all, this is my next project. Should keep me busy for a little while…Cheers Mark
All the Hull Scuttles (164) have been drilled out as well as the Mesh Curtains. The Stern Lower Boat Deck has now been added along with the small Fo’csle. As you can see the fit at the Bow is woeful. Some Putty and Plastic Rod to come to rescue this. More to come soon…Cheers Mark
Ok Putty and Plastic Rod have been added to the affected Area and been sanded back to remedy the Fault. Photo Etching has started with the Deck Openings being Grilled over and Ship Railing has started. More to come soon…Cheers mark
Nice job on correcting the fit problem. And good luck with all of that PE![;)]
Those scuttles you drilled out were the portholes so if you are doing a late fit Zuikaku those would have been covered over with armored covers and I do believe there are actually supposed to be portholes on the foreward bulkhead that you were working on which can be added with careful use of a pin vice.
BTW Scuttles are actually what is refered to as rain gutters on ships where you have holes in the deck that carry water from the deck to the exterior of the ship to prevent water build up on deck.
You will have to check the source of your info. Scuppers are the Deck Level Runoff Drains and Scuttles is the English way of saying Portholes. RainGuards were added abocv Portholes. I know that they were plated over later in the War but if you looked at the Wording on the Box Art it was correct for the period time of Pearl Harbour…Cheers Mark
A scupper is indeed an outlet for for water runoff, but a scuttle is a small covered hatch that allows personnel passage through a deck or sometimes a bulkhead. Portholes and scuttles are not the same thing. I am pretty sure the definition is the same in British (Queen’s) English as it is in American English.
Gentlemen I hope this clears up any confusion…Cheers Mark
OK, when in GB or the Commonwealth, a porthole can be called a scuttle. [t$t]
I will enjoy this one,looking forward to the distinctive deck camo
A deck camou will not be a pearl harbour version.
Cool…
Thanks for the comments Gents. Much appreciated…Cheers mark
OK the Bow and Beam Area have basically been completed with P/E for the Railings. I raided some older Sheet for the the Main Hull Deck Hatches. More to come soon…Cheers Mark
Keep 'em coming!
I shall do my Friend. Will have some more Pics up soon…Cheers Mark
Perfect work. Which PE sets you have choosen to use and maybe there are more, which you have considered not to use?
Thank you for the comments my Friend much appreciated. I am using 2 Sets of P/E which are specific for this Vessl. The Lion Roar Set is for the Flightdeck details and the MK1 Set includes all your pre-cut Railings, Ladders and Flight Deck Netting etc…Cheers mark
Mark,
Beautiful work sir, I’m very much impressed. I am amazed that you can work in such a small scale and be able to work with photo etch parts; my hat is off to you. Please keep the photos coming.
Steve
Thank you for the comments Steve. Much appreciated. And the P/E continues. More of the Deck Side Galleries have been added along with some more P/E. The Lighter gives you an idea of the Kit’s size. More to come soon…Cheers mark
