1/700 'Doolittle' Hornet Kit suggestion?
I’m looking to get a 1/700 Doolittle Hornet and I’ve been trying to research the kits that I’ve found available.I did a quick search here and found a few details on the flight deck issues and island issues on different kits.
I know that Tamiya, Trumpeter and MiniHobby have kits of the Hornet all of which I’ve found for aprox. the same price.So, if I take the price out of the equation, which kit would be better for a rookie ship modeler yet not in the bathtub toy stage.
I have the Trumpeter 1/700 New Jersey 1983 & see that it’s got a lot of detail and seems a bit complicated. Nothing I can’t handle but I’d like to start my 1/700 ship building on an easier project.
I’d like to try out a carrier that may be a little simpler yet still well detailed. Is that possible or is it an oxymoron?
In addition, the detail of the 1/700 B-25’s are important also. I’d rather they be more detailed than less if that makes any sense.
So if the costs are close enough, which kit is the better of the bunch?
Thanks, any info is much appreciated.
Adrian
Buy one and model it. Really. Then work on what you have learned is “better”. You won’t be disappointed with the results.
You may want to Google “Review xxx” for each kit that should give you some good feedback. I hope to build one some day, if I live long enough!
A bit of an oxymoron but it appears Trumpeter is what you are after: better details (aircraft in clear plastic, with seperate propeller/landing gears etc, however if you are unfamiliar with working with clear plastic be prepared to break quite a few - they are brittle and and need particular attention when removing from sprues etc)
Tamiya’s is for a simple build, Trumpeter being more modern is more detailed but probably 3x as many parts. Minihobby one is a poor knockoff of the Tamiya kit so best to avoid. The Trumpeter New Jersey kit being their earlier kits is fairly bad - average fit and annoying parts break-down. If you find that daunting then you might get turned off the prospect of making the 50 odd 20mm oerikons in the Trumpeter Hornet. However best way to overcome it is to dig in and go build, then you either find your limits, or stretech it.
The good news is that the Trumpeter’s 1/700 B-25’s can be had fairly cheaply in an individual set, so replacing broken bits doesn’t require a complete new kit. Cheap upgrade for the Tamiya kit too, as the aircraft in the Tamiya kit are pretty basic (no props, undercarriage represented by simple moulded-on posts).
Tamiya’s kit had an interesting approach (for a '70’s kit) to the 20mm’s. The gun barrels had to be cut from a length of copper wire.
