1/48th Scale Saturn V
Two of them.
All four glued to the main tube.
Now for the four segments going between the fin shrouds.
BTW, this is designed to fly.
It’s a BIG bird - must be about 7’6" tall when complete? That’s some serious work, for sure.
I used epoxy clay to encapsulate the end of the eyebolt. A shock cord will be attached to this.
I’ve sanded the end of the engine tube to receive the engine retainer using JB Weld.
This is the two piece retainer.
One part epoxied to the cardboard tube.
Now the screw on half capturing the engine and preventing it from moving in either direction.
This is the original solid resin CM. The shoulder was too large to fit properly into the SM tube and I have no lathe to turn it down.
The CM on the left is from Shapeways. Lightweight and hollow. Better definition in details as well.
Three piece LES from Shapeways. These are 3D printed parts from them.
Business end.
The CM with a coupler glued in it.
After several coats of primer and an initial sanding.
Spot putty appled to the CM.
