Thanks Marc and Reasoned.
Gloss is dry and the decals are on. I used the kit decals, and sort of wish I didn’t. They are very matt in appearance, which makes the film still stand out after 3 coats of Alclad Aqua Gloss! The white is also transparent, which was hard to notice until the decals were applied on the model. This made me source some fuselage stars from an Aeromaster sheet. Here you can see the issues:
Its not the end of the world, but next time its aftermarket decals!
Ahhh - decal show-thru is a bummer, but it looks really nice otherwise. Do you dare touch up those areas with a little white paint?
I suppose I could. I would wanna airbrush it though, and masking off the star shape would be tedious. I’ll just let it go this time. Still doesn’t solve the visible carrier film though, such as around the #15.
Finished! I mixed up a semi-gloss mix using Gunze clears and I like the look of it. I added an oil wash and some post shading here and there. I think the fuel gauge decals came out good enough. Canopy and Ez line antenna attached. Zvezda’s clear parts are pretty nice. The kits draw backs are the poor decal quality, the too small wing root intakes, clunky wheels, and the fuselage to wing attachment not being on a natural panel line. I could also say the prop is clunky, mis-shaped, and assembles in a way that makes it almost impossible to paint the blades and spinner separate. Is it better than the Eduard kit? Hard to say. A Profipack kit with pe and masks, as well as Eduard’s excellent decals are hard to beat. But I like how this Zvezda kit turned out in the end. Thanks for looking and commenting.
Excellent work!
Turned out really good Nathan! I know where to reference when I start building mine.
Great work on the Yak! Thanks for posting the pics. Turned out awesome!
Eagle90
Yep, sweet build
