I love the Spitfire. The Merlin versions, as far as I’m concerned, were the most beautiful aircraft ever built and I have a particular fondness for the MK I. To me it was purest form of R.J. Mitchell’s design coupled with the role it played in that pivotal part of world history. Who knows what would have happened if Britain were unable to beat back the Luftwaffe in those dark days. This all prompted me to embark on a MK I build with the phenomenal 1/48 Tamiya kit . I procured an Eduard PE set, Ultracast seat and wheels. I haven’t decided on which squadron yet.
I started with the cockpit. I added some miscellaneous PE to the seat bulkhead assembly and then all interior sections were sprayed flat black. I added the very nice PE dash. I normally bypass these but this one is fairly detailed and colorful. I mixed RAF interior green with the Tamiya recommended colors. It looked too green so I added a dash more grey. I then sprayed the interior. The Ultracast seat was painted to simulate “bakelite”, or whatever was used on early spitfires. I dont know if bakelite is correct for MK I Spitfires but I like look of it, which was Tamiya flat red mixed with red brown. I painted the O2 bottles light blue, primarily because I have no clue what color there were supposed to be and I wanted to add some more color.
I opened up the gun ports holes in the wings and added .08 brass tubing to sumulate the Brownings. I tried to stagger how far they stuck out by using the access panels on the top of the wing as a reference guide. I then sprayed them flat black, drybrushed them with silver, then closed up the wings with Tenex. You have to really look closely, especially on the inboard 303’s, but you can see them. I think it will add to the overall look.
Well…here I am,. A couple of hours work and the frame is together. I still have work at the wing roots and need to add the stabilizers, but its spot glued at the leading and trailing edges. So far, its a perfect fit. Gotta love these Tamiya kits. For those interested, I have a trick I use to check seams. Once done sanding, just before fine grade sandpaper to smooth everything, I use a silver Sharpie along the panel lines which magnifies areas that need more attention. Works everytime.
Looks like I’m gonna have to decide on a squadron soon! Stay tuned for more…
Joe
