1/48 scale fuel barrels
does any one know how to remove the seem that is on top of the fuel barrels I can remove the side seems with no problem but the top and bottoms are very hard to do any idears would be very helpfull-thank you
I would cut a thin piece of sheet styrene and glue it on the top.
Ok thanks
If you’re a tool person, look into getting a micro-chisel - great for eliminating seams in really tough-to-get-into places.
If not, sand what you can and then use a bit of thin cement (like tamiya thin). It’ll soften the seam line and you can literally, brush it away. Don’t push too hard, though, or you’ll end up with a fugazy looking barrel top.
-Fred
