I have started this one, and unfortunately I don’t do raised panel lines so the first job will be to re-scribe everything. I will be adding loads of Eduard interior and exterior detail…
I started by removing all the raised detail off the port wing and re-scribed the panel lines and added some rivet detail with my “Rosie”
Wow looks real nice. Excellent scribing. What tool are you using?
Thanks Nathan, i use the Metal Foil scribe tool for the panel lines and the Trumpeter "Rosie"for the rivets
Well I have one wing together so far and there is a LOT of work ahead…
Looking good - you’re off to a nice start! That’s a big model to re-scribe! Looking forward to seeing more.
Steve
Somebody did aftermarket cowls for these kits, would look awesome on this build. Just wish I could remember who did them… It was a small company that mainly focused on sci-fi.
Quick Boost does some resin engines, and I believe a separate set of cowls as well…
