1/48 Revell A-6E Intruder Complete
I’m going to start a WIP soon on Revell’s 1/48 A-6E, but I have a couple of questions. I’m trying to decide whether to build the TRAM version or not. The markings for the TRAM version are for VA-35 on the USS Nimitz. I like those markings more, but the large circle decal looks like it might be trouble to fit over the curves on the tail. Does anyone have any experience with this? Which instrument panel goes with which version? Also, if I did the TRAM version, would it still be acceptable to use the snakeeyes and rockeyes? I tried some Google searches but didn’t really get anywhere. Thanks in advance.
Hello!
I don’t know the kit nor the markings you mention, but I’d say don’t let a decal stop you! It’s a good thing you’re on a lookout for trouble, no go and overcome them! It’s always a good idea to scan the decals first. This way you can make replacements should something happen. I have had decal professionally printed several times now and the ones I get are very thin and responsive to decal solutions, so I know I’ll be able to put those even on top of pretty wild surface. If I knew my decals don’t conform well, I’d re-draw them and use the custom printed one for easier application. Or you could transfer the patterns to a masking foil and cut a mask and paint the markings - just a few ways to overcome a problem. I hope this helps you and you give it a shot - good luck with your build and have a nice day
Paweł
Thanks Pawel. You make a good point that markings shouldn’t scare me away from a build. I did some more looking around and I think I know which instrument panel to use, but I’m still not sure about the loadout for a TRAM.
Yes, you can use Snakeyes and Rockeyes on a TRAM Intruder. The TRAM is just a sensor turret to give the aircraft more all weather capabilities. It has a FLIR to see thru clouds, rain, smoke, etc. and a laser to self designate targets for laser guided weapons where conditions allow their use. A non TRAM Intruder needs a laser designator pod (Pave Knife or such), a buddy aircraft with a laser, or some other laser designator (GLD, etc.) to employ those weapons otherwise. TRAM Intruders more often than not carried “dumb bombs” as opposed to PGMs on combat missions in the Med, Gulf, and Middle East.
Thanks Stik, I figured as much but I wanted to make sure. I don’t kno too much about loadouts on modern aircraft so I figured I should ask just to make sure, especially with so many knowledgeable people here.
You’re welcome. I don’t know how often a mixed load of Snakeyes and Rockeyes was carried, but you won’t go wrong with pretty much anything in the Navy inventory of air to ground weapons, guided and unguided, from the late 70s onwards thru the mid 90s.
Your guess would be better than mine Stik. The kit came with 12 snakeyes and 8 rockeyes, and I like to build my planes with as much ordnance as I can load up on them. I feel like it makes them look meaner
Yes, I built the kit when it was first released many years back. I loaded mine up with Mk.82 slicks and drop tanks. There are plenty of load outs to choose from. The choices are yours.
I’ve finally been able to get a start on my Intruder after being waylaid by a cold and a stomach bug. I started in the cockpit and I’m still working on it, but I was wondering if anyone had any decent pictures of the deck behind the cockpit. I can’t seem to find any pictures of that area on an actual aircraft, and of all the builds I’ve seen online, each one is different. This is the area I’m talking about.
I think I’m finally finished with the cockpit. I did it OOB. I’ll probably go back and repaint the yellow on the ejection seat handles, I’m not really happy with how they look. There is flash on almost every piece so clean-up takes awhile. And putting the seatbacks together was a pain. I also realized Revell didn’t include anything to cover the backs of the seats so I just put some styrene sheet in there to blank it off. Any comments/critiques welcome.
Boy that pit looks great. I built this kit about 10 years ago. I don’t recall and issues.
Great start on the cockpit, I’m looking forward to more!
Toshi
Thanks guys
This is the only photo I have that shows the area aft of the cockpit at all, but it looks very busy.
And a photo from the Detail & Scale Vol. 24 of the A-6:
Thanks for the pics John! I thought I replied earlier, but I must have closed the window before submitting it. Oh well.
It’s been awhile but I’ve finally made a bit of progress on the Intruder. I’ve got the fuselage together and the cockpit installed. There was a bit of a gap behind the cockpit and the fuselage and some small ones here and there along the join. I filled them with Testor’s contour putty and spent the next week or so sanding it out and getting rid of the prominent seam line since there was a bit of a fit issue and there was a step along the entire join. To protect the raised panel lines, I placed masking tape on top of the panel lines around the area I was going to sand. Pretty time consuming but it worked and the seam looks pretty good to me. I’ll have to check it out when I prime it after I get the rest of the plane assembled. I also primed and painted the landing gear bays.
I had some experience with Intruders from 77-91. You can hang snakes and rocks on the aircraft together, but it really was not practical to plan on dropping them on the same mission. Ballistics are really different, and you really only made one pass and then went back home. If you want to be realistic choose either rockeyes or snakes. That would be a more realistic combat load. By the time TRAM came around there were fewer snakeye type missions, more rockeye.
Not saying there were not mixed loads, but mixed load usually meant one or two rockeyes and an LGB on a surface patrol mission. if you didnt use the weapons, you could bring them back.
That said, hanging a mess of ordnance on an Intruder looks pretty impressive. Maybe get some exta rockeyes or snakes.
good luck. can’t wait to see it finished.
Looking good so far, Like you I think they look mean loaded to the gills with ordinance. Look forward to seeing this progress along
Hey Bob, looks to be a fun project. I searched my files and here’s a couple of shots at least showing details. Watching!
Max
Here is a good list of various ordnance loads carried in Desert Storm. Some links to example photos as well.
http://www.dstorm.eu/pages/loadout/a-6e.html
Thank you very much guys! There’s a lot of good information here, it’s almost overwhelming. I did a little bit more searching and found another interesting loadout with a fuel tank, AGM-84, center-line tank, MER with rockeyes, and GBU-12. I’ve got some time before I’m ready to put some bombs on her, too much real life getting in the way of benchtime.
