Hi folks. I hope you are all having a good day.
I am to the point where I felt like sending up a few WIP images on my in progress MIG 29. It is the older Monogram 1/48 kit. Please bare in mind that my painting skills have gone severely downhill since my aneurysm a few years ago, so be kind. I know I am probably going to be doing a lot of touch up work on the cockpit. Luckily, I have a big 8oz. can of ELO standing by. [;)]
Okay, here are some images. The first image shows the two air intake tunnels, with their doors in place in the closed position. These still require some fine sanding. The pieces aren’t quite up to Monogram’s normal standard for fit and finish. I spent about an hour sanding and buffing just to get them where they are in this image, and I still have more to do where it connects with the fuselage and the back section of the air intake tunnels.
!(http://i77.photobucket.com/albums/j75/sparrownightmare/MIG29 WIP Images/MIG29WIP2.jpg)
This is a good view of one of the tunnels in a raw state before any sanding. As you can see, the glue monster got to work on this one before I did any sanding on it.
!(http://i77.photobucket.com/albums/j75/sparrownightmare/MIG29 WIP Images/MIG29WIP5.jpg)
Here is another shot of a tunnel front after some minor preliminary sanding and cleanup.
!(http://i77.photobucket.com/albums/j75/sparrownightmare/MIG29 WIP Images/MIG29WIP6.jpg)
This image shows the cockpit sub assembly in place in the fuselage. I initially used Tanyia liquid glue to hold it in place and then some Great Planes medium gap filling CA glue. After I had it glued, I used some accelerator to instantly harden it. This is a huge time saver. I also found these neat little glue tips on eBay, they are the finest I have ever seen and they save a lot of grief since you can get the glue exactly where you need it to fill gaps.
!(http://i77.photobucket.com/albums/j75/sparrownightmare/MIG29 WIP Images/MIG29WIP3.jpg)
This image is the top of the main fuselage with the cockpit installed. Like I said, I need to do a lot of touch-up work on it, but it’s a start.
!(http://i77.photobucket.com/albums/j75/sparrownightmare/MIG29 WIP Images/MIG29WIP4.jpg)
This is the bottom section of the fuselage after being glued and clamped together with the upper section. I used simple MM Black label glue on the fuselage sections. I did not want to risk CA remains on areas where it would show a lot. I am still not happy with the seam between the tunnels front and back which is part of the bottom fuselage section. I am going to sand it as close as possible and then use a combo of CA gap filler, white putty, and a lot of elbow grease to smooth it out. You can’t really see it but I somehow got a big glob of CA on the inside of the air intake tunnel on the inboard side. I will need to use a combination of debonder and sandpaper to get rid of it.
!(http://i77.photobucket.com/albums/j75/sparrownightmare/MIG29 WIP Images/MIG29WIP8.jpg)
This last image shows the assembled fuselage section from the top at an angle. It’s out of clamps now and I will be spending the better part of this afternoon sanding, filling and sanding again. Oh, and the nitwit that designed the mold for the air intake doors need a new pair of glasses. I noticed after assembly that there is a big gape between the door and the tunnel which is going to take a bit of minor surgery to fix.
!(http://i77.photobucket.com/albums/j75/sparrownightmare/MIG29 WIP Images/MIG29WIP7.jpg)
Well, that’s about it for this installment. I’ll send more up as it progresses. Any suggestions are really appreciated. I have no allusions about my remaining skills but I notice that they improve a bit with every kit I do. Modeling is great therapy for recovering coordination skills I guess.
Rich
