This next build is the 1/48 ICM C-18S “Magic by Moonlight” Air show Aircraft. The aircraft was also nicknamed the “Beech Twin 18”. The pilot, Matt Younkin performed aerial stunts at many air shows. One of the most visually stimulating displays was Matt performing his stunts at night with all the lights (plus extra lighting) turned on. With that in mind, I will be building this “in flight” and will be using many LED lights and some fiber optics to replicate the aircraft performing its visually stimulating night time routine. I estimate I will need about 20 LED’s and about 2 feet 0.5mm fiber optic lines.
I began with the instrument panel. The kit has a generic layout of gauges. I searched online and located a photo of the C-18S instrument panel. I scaled the photo and made a decal out of it. The panel was then sanded smooth and the area behind the gauges and displays was cut out. The decal of the panel was applied to a thin piece of sheet styrene and glued to the front. I then made a light box behind the panel to enclose a “warm white” LED to back light the instrument panel. I then dug into my scrap photo etch drawer and found the flight control levers for the center console. Moving onto the fuselage I installed the interior bulkheads and scratch built a channel with clear domes to house the cabin lights.
Another area that required modification is the wings. First, the kit only has one wing light and the actual aircraft has two. I measured the port wing light and duplicated it on the starboard wing. I then drilled out the under wing landing lights so I can later install clear lenses and LED’s. The last modification was to trim off the molded wing tip lights, drill a 0.5mm hole into the wing tip. I took a fiber optic line and heated the one end to form the wing tip bulb and fed the fiber optic thru the hold and into the wing. I will add the red and green LED’s. I am now laying out where the rest of the fuselage LED’s are going as well as the engine cowl lights.
That is a great kit, probably the best Twin Beech available. Love that instrument panel.
The D-18 is an icon of aviation. Almost every airport has a ramp queen out in the ramp boonies (they end their life requiring an expensive main spar mod). They held the record for longest production run until replaced by amore recent Boeing liner.
Welcome to week two of the C-18S. I am calling this the “Let there be light!!” week. I spent this week adding the lighting to the wings, tail and some of the fuselage. The mounting of the fiber optics and the LED’s takes a little time as these are glued down using acrylic gel. The acrylic gel takes a while to completely cure and everything needs to be glued down in sections. Starting off with the wings I worked on the wing tip lights and on the navigation lights on the tail. I drilled 0.5mm holes and added 0.5mm fiber optic lines. To simulate the light housings I used a flame to slightly melt the one end of the fiber optic lines. Once mounted they were glued using acrylic gel to the top of the PICO sized LED’s. Then the LED’s were then glued in place. For the under wing landing lights I cut disks from a clear tree then sanded and polished the one end and glued an LED to the backside. Two more LED’s were mounted on the leading edge lights. I drilled a 0.75mm hole on the center of the lower wings and added a lens. This will later have a flashing red LED mounted behind it.
With the bottom side of the wings wired I then worked on the topside. The aircraft has lights mounted inside the cowls to illuminate the engines during flight. I utilized two PICO LED’s and mounted them on the top side of the cowls. While the acrylic gel was curing I started working on the fuselage. The instructions have you cut off the nose and replace it with another one that has two spots for lights. I drilled these out using a 3.0mm drill. I then test fitted two 3mm LED’s. I marked the front side with a marker then sanded the tops of the LED’s so they sit flush to the nose. Once they were modified I polished them to look like the light lenses. I am now working on the engines so I can finish the wing assembly and get the wiring routed to the aft section of the fuselage. The wiring will ultimately be fed thru the center of the rod that will hold the aircraft “in flight”.
Moving forward with week three of “Magic by Moonlight” I assembled and detailed the engines using the photo etch add-ons. It was a little strange that the kit engines were not molded with the cylinder fins but Eduard was kind enough to provide these in the photo etch set. I then mounted the engines into the wings. I had to files two small grooves to clear the wiring for the cowl lights.
Next came installing the seats into the cockpit and cabin. The photo etch set does not include the seat belts so I made my own using some 3M cloth tape. Since I will be displaying the aircraft in flight I took a 1/48 WWII pilot to place in the seat. In order to look like the actual pilot Matt Younkin I used a Google image of Matt and a 1/48 ground crewman to modify the pilot to look like him with his red shirt and red ball cap. Matt was then placed in the pilot seat.
I then began assembling the fuselage. With 18 LED’s inside I routed all the wiring to the tail section and soldered all the connections. Then the styrene rod was installed and the wiring was fed down the center of the tube. After getting the wiring tucked into the tail section I was able to get the fuselage together. Everything lined up well considering I had to install the wings and tail on half the fuselage so I could route the wiring then carefully put the fuselage halves together. With the aircraft assembled I performed a light check and all the lights were working. I am now starting to mask the fuselage for the paint scheme. I should have all the painting and decals done in the coming week.
Check out the short video of the light check in the build log.
Check out all the photos and details from the start in my build log at https://davidsscalemodels.com/build-log/1-48-c-18s-magic-by-moonlight/
Week four of the “Magic by Moonlight” was the painting and decaling of the aircrafts scheme. I started off by using kapton tape to mask the windows and liquid mask for all the lights. The aircraft was then sprayed with Testors Ferrari Red. In order to get the scalloped paint scheme I scanned in the kit instructions of the scheme then scaled them to match the model size. I then placed the scanned photos under the glass work surface and made the masks using kapton tape. With all the masks applied the aircraft was the sprayed with Testors gloss black.
While the paint was drying I reviewed the reference photos of the actual aircraft. There are numerous company logos for the sponsors the aircraft near the tail and on the fuselage above the main wings. The kit decal set does not include these. I searched Google and found all the company logos. I then scaled and made my own decals. All the decals were then applied and the entire aircraft was sprayed with a clear gloss. I then detailed and painted the propellers and installed them. I used some 30AWG bare wire to make the small whip antennas for the top of the fuselage. I also ordered a brushed nickel nameplate which will be mounted on the base of the display stand. All that is left to do is to mount the aircraft, wire up the base, and then make the smoke trails to complete the project.
I have completed the C-18S “Magic by Moonlight”!! The aircraft was mounted to the base. I ran the wiring thru the support tube and attached the wires to a connector at the rear of the base. This allows me to use the AC adapter that has a switch on it or I can hook up a 9V battery to illuminate the aircraft. The nameplate was then affixed to the base. I used two styrene rods coated with acrylic gel and used cotton balls stretched and wrapped around the rods. These were then shaped to create the smoke trails used in the stunts. This completes the display.
The kit itself is a nice kit with only some minor sections requiring putty. The kit decals worked very well and conformed to the surface perfectly. The instructions seemed to be laid out well. However due to the logistical assembly with the lights I had to attach the wings and tail section to half of the fuselage and attach the other half afterwards. I ended up using the following to create the lighted effect:
1 pico LED warm white for the instrument panel
12 pico LED’s in cool white for the wings, cowls, tail lights and cabin. Tail lights also used two 0.5mm fiber optic line.
1 pico red and 1 pico green for the wingtip lights. These were attached to two 0.5mm fiber optic lines.
2 pico flashing red for the fuselage
2 3.0mm LED’s in cool white for the nose lights
So there are a total of 19 LED’s and 8” of 0.5mm fiber optic lines. All the wiring was routed to the tail section and soldered in parallel then two wires run thru the mounting rod to the connector at the rear of the display base.
I really enjoyed building this and I really like how it turned out. Thank you for following along and hope you enjoyed this build. Happy Modeling!!
Check out all the photos and details from start to finish in my build log at https://davidsscalemodels.com/build-log/1-48-c-18s-magic-by-moonlight/
Hey, man you’re breaking my heart. With this presentation and as I’ve said, She’s so gorgeous and an all time favorite of mine, and great job for sure but, she Cannot be mine! Sob,Sob, LOL LOL. Luv it! T.B.
