1/48 Hasegawa Ju87B-2
Built out of the box with kit decals. Excellent kit also have the G to build.
Very nice, the splinter scheme looks excellent. [tup]
Canopy fit looks a little rough…
Looks very nice. Love the yellow nosed birds. Is the canopy loose?
I built the G, and i found although the shape and panel lines were good, the pit seriously needed an aeries upgread to look the part.
…Guy
Frank Thank you the kit came with a mask for the splinter
Mike Yes the pilots sliding portion is loose Also my oldest cat decided to sink her teeth into it and there is a slight crack. [#oops]
Guy Thanks [#ditto] for the reply to Mike.
I will also add an AM cockpit to the G when I build it
Good wok. Keep them coming.
Regards, Rick
You should take a small piece of sheet styrene and make the prop for the siren as well… If you have any laying around, the Pro Modeler PE bomb fuzes are about the right size, too…
If you want, I’ve got a couple laying around here some’eres I’ll send ya…
very nicely done… hey, the canopy framing is perfect! :wink: well done, thanks for sharing
Nice job, Dont see enough stuka’s around here. Maybe when the Bf110 craze blows over…[:-^]
