1:48 Carrier Deck Questions
I’m getting ready to build a modern US carrier deck and was wondering if anyone knew the dimensions of the lines and the spacing for the padeyes (tie down points). I haven’t been on a flight deck in over. Ten years and my memory is a little vague. I was going to us 220 grit sandpaper for the non-skid. Any other options? Thanks for any info in advance.
I wish I can help but I am not into ships. If you can post this in the ‘Ships’ forum you may get responses. Hope you get an answer… good luck! [Y]
As mentioned the ship forum would probably be able to help you out.
Barring that than using measurements off you model to scale off photos will give you a good ballpark figure.
Navy. mil has lot’s of good reference pictures.
