1:48 B-1B with lights and sound
I just bought a Revell Germany 1:48 B-1B and plan to build it wheels up/bomb bays closed (shame because the kit includes a lot of nice interior detail parts). Anyway, this cavernous interior begs to be used for something special.
Rescue Heros and X-Men both have toy jets with “realistic” jet sounds and flashing lights. I’m looking at buying one of those and gutting the electronics to get sound, navi lights (fiber optic), and anti-collision beacons on the big B1B. Maybe add glowing red afterburners too.
It will be hung from my son’s bedroom ceiling so I’m thinking that a mercury on/off switch could turn on the system whenever I pull the nose down slightly (push up to turn off).
Anybody ever done something like this before? I did a forum search (it works again) and came up empty-handed. I’d rather not re-invent the wheel if somebody’s already done it before and can offer any materials/construction advice.
Sounds like a good project. One of these day’s I’ll probably outfit one of my planes with lights and motors too…
I would be concerned using mercury, especially around kids. A safer method to do the same would be to use a ball bearing or steel ball (I remember getting some ~1/4" diameter ones from Lowes a few years back for a project) housed in a tube… Radio Shack has a series called “Engineer’s Mini-Notebook” written by Forrest Mims, and one of them shows how to set it up, though if I remember correctly, the main part is now sort of obscure/obsolete. Once you see it, you should be able to figure out a workaround if you can’t find all the parts.
Another big concern is how to replace the batteries (they’re going to die eventually). If I ever motorize something, I’ll probably end up hiding the batteries in a base, but if you’re going to embed everything in the body, you’ll want to give it some thought.
One last thought would be to reinforce all of the joints with epoxy and/or sheet styrene… I’m guessing that weight of batteries + electronics will test the limits of the normal methods of construction.
Good luck.
I did a simmilar thing a couple of times many moons ago. I lit the interior of a 1/72 AC-130 gunship with grain of wheat bulbs. I hid the battery box in one of the wheel wells and put a hinge on it so it could be opened to replace them.
I also lighted the cocpit and all formation light with LEDs and put a motor to spin the rotor blade on a 1/32 AH1G Cobra. I used regular flip switches for both models. For the cobra, I bought a blinker circuit at Radio Shack for the blinking anti-collision beackons. Came out pretty good.
