1/48 AVF Club´s Tiger I
Hello everyone!
I´ll start my participation in this forum with this 1/48 AVF Club´s Tiger I.
I´ll not say anything about the Tiger tank … may be the most popular tank in modelling history!
The kit is just … wonderful. Nice fits, impressive detailing … and for a modeller like me who do not like too much assembling kits and extra-detailing, is the perfect choice.
I just added the armorscale metal barrel for the gun and the friulmodel tracks (I REALLY love Friul tracks, I always use them if possible)
Here, you can see the model assembled:
Step 1: Priming
I normally use Gunze 1200 primer or Tamiya´s metal and plastic primer for this task. I spray the Tamiya´s primer directly in a cup, and then, I airbrush the product all over the kit in thin layers. No matter if in the first aplication you do not cover all the kit. With Gunze´s product. is the same, but I thin the product with Gunze´s thinner about 50%-50%
Do you have problems when priming? Rough surface full of awfull grains? No matter!! Me too!!. Just do the following.
  • With a rough brush, carefully try to remove the dirt ans dry particles over the tank´s surface.
  • If this fails, use a ultra fine sand paper and with patience, sand and polish all the surface. Be carefully with PE and little parts . know, carpet´s monster is always lurking …
The result should be and absolutely soft and polished surfaces. This will help you to get a really nice base coat in next step.
Step 2: Base Color
Using Tamiya´s white and panzer grey, I started airbrushing the different surfaces of the vehicle. I always try to paint different shades in the diferent surfaces and textures of the tank to have a more colur rich appearance.
I also added some vertical strains using panzer grey in order to help to the future painting steps. If you´re going to dirt a surface, let´s do it since the first moment! (Luciano Rodrigez dixit). That´s the reason why I painted with XF-72 the lower part of the tank and the wheels.
Take your time, this is the most important step. Use masking tape if neccesary to help you painting in different color shades the different surfaces. Work a little … stop working, look at your kit for a moment … think, continue working … be relax work listening to your favourite music!
Once you´re happy with the result (well … actually I´m never completely happy with the result, bur the kits must be finished!!), I always add a really nice coat of Tamiya´s clear airbrushed to have a glossy finish.
Yes, you read correctly. Glossy finish. This glossy finish is perfect for the pin washing were I use Tamiya´s enamel paint (90% black + 10% matt earth). The thinned paint runs really easyly over the surface with this gloss finish. And do not be worried, once you continue working, oils, filters … will make the kit matt!
Step 3: Dirt, scratches and chips. Drybrushing!!
Yes, again you read correctly. Who said drybrush is dead??. The technique is easy.
Using any acrylic paint, your favourite, apply the technique of drybrushing in the tradicional manner, focusing on the edges and areas close to them. Just use your common sense and some imagination to get an atractive and realistic result.
Before the paint gets dry, with a cotton swab you can change to your will the shape of the spots, using a dental teeth for more precision when required.
Step 4: “Cold dirt”
Using again acrylic pains (oils can be also perfectly used at well), I start to add some cold dirt all over the tank… but … what´s cold dirt? No … not necessary to put your paints in the refigerator :), “Cold dirt” is just a way to say that you should only use “cold” colors like black, grey, dark brown (with any trace of red!), so on
Here, the results:
in detail …
Next step … vertical dry strains and … let´s start painting the wheels!!
Many thanks for looking and hope you find this post interesting. Stay tunned! … soon I´ll post more steps!
Want to see some other works from me?
/forums/t/130749.aspx
See you!
[quote user=“Jose_Luis_Lopez”]
!http://i258.photobucket.com/albums/hh263/j_l_lopez_ruiz/DSC_0057_444.jpg
[quote]
You know what, this tank looks really awesome with a silver and gold gun barrel and silver treads. Makes it look, um, “blinged” out! Love the step-by-step, and will definitently attempt it on my next tank.
Lovely weathering Jose. Are you featuring this in a dio?
Excellent work Jose. Looking forward to the finished Build.
Regards, Rick
Its really coming along great so far - I will be following along!
Beautifully done Jose! Thanks for sharing your technique’s.
Looks good so far.[t$t] Count on me following along.
fantastic work, although i can never justify coughing up for fruils.
Thank you very much for your warm welcome and for your opinions!
Now, the final pictures of the tank:
Unfortunately, the black background is not the best one to get a nice shoot of the wheels and the wet weathering (too much contrast in the pictures). Soon I´ll receive a new background more suited for this vehicle and I´ll post new pics.
Any opinion or suggestion will be highly appreciated…
Regards!
Your pictures look fine to me [B] What a way to introduce yourself - Beautifully done!
Your model is coming along beautifully so far, can’t wait to see more.
Nice work! I enjoyed the progression of photo’s through out the build.
Welcome to the forums! Nice work on the quarter-scale Tiger! [Y]
… a little vignette … still not finished! … no weathering on snow … still no humidity in the ground … dirt … too much still to do!
Many thanks!
And now … the base finished … just missing the figure …
… a BIIIGGGGG tree! [:D]
The base without the kitten
And some shoot details:
Any opinion or suggestion will be highly apreciated
Regards
WoW!! What a beauty! Great work, the finish and weathering on your kitty is fantastic and very pleasing to the eyes!!! It looks right at home on that base too!
My friend, this piece is simply STUNNING! probably one of the best models ive seen. Please show us your secrets!
The final!
Figure form Evolution … impressive!
Thanks for looking!
The tiger is great,but the 1/48 figure is unbelievable !! [Y]
Jose,
Looks great!!! Good work
