1/48 Accurate Miniatures Avenger Instructions
A little while ago I purchased a 1/48 AM TBM-3/TBF-1C Avenger kit at a show, and after getting home discovered there were no instructions with it. I found a place online where I was able to download the instructions and I thought things would be fine. Tonight I was planning on moving them over to my Google Drive only to discover my wife accidentally deleted the instructions from the computer, and now I can’t find the site I downloaded them from originally. Does anyone have a pdf copy of the instructions? I’ve heard that Italeri re-released the same kit, so those instructions would work too. Google is not my friend tonight…
Is it kit # 3404 from Accurate Miniatures?
If so, I have that kit and the full instructions. They are HUGE, so copying them will take some doing. I can do that but I won’t have time for a few days, probably this coming weekend.
Thanks for the quick response Brandon! The kit I have is #7803. But I think I might have found a solution. I found a link on http://web.archive.org/web/20090210023605/http://www.accurate-miniatures.com/support.shtml for TBM instructions, and it looks similar to the one I downloaded. If that looks just about the same as yours, then don’t worry about copying it. One of those cases where if I would have tried one more thing before asking for help I would have found the answer. [:$]
Ya, my kit instruction don’t look anything like that. Mine look like a road map all folded up and the instructions are spread out over the both sides and not evenly. Very different.
OK, I’ll compare the pdf in the link to the kit I have and double check that everything lines up. I’ll let you know how it works out.
