Did you ever do this? I am wanting to build the Indy,
If I could develop a superpower, it would be to mind-control whoever makes the decisions for Trumpeter into putting out the Forrestals, the America, the angle-deck Midways, more angle-deck Essexes and the Ford in 1/350 plastic.
Islands and other parts for two Forrestals and several Essexes are available in most popular scales, including 1/350. Essex islands include WWII fit, Korean War fit, and Vietnam War fit.
So Steve I guess the question is, can you print a 1/350 Forrestal hull to put the islands on?
Bill
I would buy a 1/350 Forrestal in a heartbeat ,regardless of cost. My father served on the maiden voyage of her in the early 50’s. Please correct me if i’m wrong but I think she was the first to have the angled deck.
Unfortunately, no, a 1/350 CV hull is far too big to be affordably 3D-printed given present technology. The 1/350 Forrestal islands were requested by modelers who intended to kitbash a Trumpeter Kitty Hawk into a Forrestal. Obviously, that’s a big conversion project. But the islands help. And for early-mid Forrestal configurations, 5"/54 double-dome “Frog-eye” mounts are available, too. The islands and mounts sell more often than one might expect. A 1/350 USS Independence CV-62 island and two mount sets sold this weekend. For a time, another vendor offered a 1/350 Forrestal flight deck to help with conversions.
Generally, the Forrestal islands sell best for the Revell 1/542 scale kits.
Best 1/350 Essex island sellers:
WWII: USS Yorktown CV-10, April 1945 Yamato sinking appearance.
Korean War: USS Kearsarge CV-33.
Vietnam War: USS Hornet CVS-12, Apollo 11 recovery appearance.
Steve,
I was a little tongue-in-cheek there, but a very informative reply.
The deck idea is a good one, seams could easily be dealt with.
Another bit that would be helpful for the 1/542 FIDs would be a replacement bulb for the bow.
Bill
Actually it was the unmodified Essex class USS Antietam. As a result of experience gained, Forrestal was the first of the super carriers to have one.
https://weaponsandwarfare.com/2017/08/17/first-super-carrier-forrestal-class/
Pretty sure Forrestal was already building when Antietam and then Oriskany proved the angle-deck concept. I also think Forrestal was the first supercarrier built; USS United States was supposed to be but was cancelled on the ways.
The Midways were sometimes referred to that way.
I know this is old but the Midway class also had the Franklin D Rooseveldt as well.
Now if someone could put out a aftermarket interior for the Hangar bay for the KittyHawk in both 1/350 and 1/700 people can proudly display their aircraft in there.
Strange to realize that the CVs of the time were designed at much earlier dates that the dates of service suggest.
The Midways ( my favorite class), were designed starting in 1940 based on Royal Navy designs using armored flight decks. This was before any USN CV had ever been sunk.
The original design had the then popular 8" cruiser rifles too.
Bill
Not so strange when you figure from thought, to operational, the process.
Thought, sketch on napkins, design, engineering, blueprints, changes, getting funding from Congress, and actual build time, then working out the bugs.
Easily 12-15 years from concept to actually launching and recovering a/c.
Just as an example, I sit in a federal advisory council, and the USFS started a forest revision plan in 2003, and still not done and approved. Used to be they were revised every 10-15 years. Now we’re figuring it will be at least double that
Speaking of which, I thought that you were supposed to be coming over to Prineville in May . . . What happened, I had beer in the cooler and everything!
Trumpeter does include a basic hangar deck. Gives you a start on building your own. Better option than a certain carrier kit from Japan. (Cough, cough, Tamiya Enterprise.)
Naval rifles are of “shrunk tube” design, which allows for replacement of worn rifled liners.
Operationally, after expending a magazine of ammo (which was near the rifiling limit of rounds), the ship would return te base and the barrels removed and swapped for new ones. The old ones would go back to the gun foundry to have the shot-out liners removed, and fresh ones installed in their place.
So, you (as a Naval Establisment) wanted three barrels for every one you put to sea. Whic meant you started rifle production early, sometimes before the keels were laid. Once Standarized, you wanted your gun foundries to run at some sort of predictale speed, too.
Which meant you built up an inventory of naval rifles.
Also, doctrine for CVs was in flux, too. Tere was a contemplation that a CV might come under surface assault (say in non-flight conditions, or unavailability of screening ships). And, having 3-4 miles’ range on DDs or CLs was seen as a distinct average.
Actual experience taught us that a/c were the much more present risk, and that screening ships were quick and easy to crank out to provect and serve CVs.
That, and no one ever managed to sort out how to make 20cm rifles useful for AAA use. 90 secnds of fligt time is tough to use against a/c at 500 fps. (300kts is 5 miles per minute).
Well that’s something.
So an attacking dive bomber bomber flying at 300 kts. travels 7.5 miles in 90 seconds.
An attacking torpedo aircraft travels 3-4 miles in 90 seconds.
Shell arrival and kill zone for a 20cm explosive shell is what, maybe 1000 feet?
In any case, the loss of attacking aircraft at Midway was mostly
either operational or CAP related.
The design problem for the Midways most likely was that with the addition of the armored flight deck (still not the main structural deck)- in order to keep the vertical CG at a point below the axis of roll (I forget the ordinate); most AAA was reduced to single 5" mounts, more 3" mounts, loss of cruiser sized rilfes and use of the 5" mounts as horizontal protection at the hangar level.
What became Forrestal was a long Midway that incorporated the angle deck. IIRC Saratoga had a slighty longer hull to reduce the angle.
Our friend Lee (subfixer) was quartermaster on Ranger.
He had a good story about avoiding the center anchorage of the Oakland Bay Bridge while sailing out of Alameda during which the Admiral and Captain were arguing about a baseball score.
“Sir, course correction?”
And so on.
Bill
While there’s no way to know, I hope the Trumpeter folks made a pile of money on their 1/350 Kitty Hawk/Constellation/JFK models - because that would encourage them to put out the angle-deck Midway class and the Forrestal class ships in 1/350 styrene. Maybe an early Enterprise too, and the Tarawa and new America and of course Ford class as well. Hey, I can dream!
Well you are talking about a almost 50 year old kit after all. Plus the kit was really USS Hornet boxed as Enterprise her hull and Island configuration were a dead giveaway.
