1/35 Dragon Leopold--Build Complete: 89 hours over 21 days!
Day 10 Log: September 13, 2004
Errors/Issues Found: 1
In a bizarre, yet quirky, fashion, the instructions for assembling the railroad ties and rails have you do some very strange things. Inside the tie slots in the embankment, there are arrows and numbers indicating which way the ties should go in…funny thing is, I’ve studied all the ties as close as possible and, as near as I can tell, there’s nothing different about them or the orientation they go into the slots. Still, better to be safe than sorry, so I am diligently following the pattern of g2, g6, g7, g6, g2, g6. g7, g6, etc. taking note that the arrows are lined up properly. Of course, when they told you to assemble the embankment sections, they did not indicate that anything had to match up with the arrows, so this could turn out to be quite amusing in the end… [:0]
Additionally, the instructions call for you to use two rails pristine as they are on the sprue, 4 rails that you remove 9.5mm from the end, and one rail that you cut in half at the 154mm mark (they only supply 7 rails but you need 8…). Measuring out 9.5mm and getting a clean cut is going to be really fun. [:(!]
Steps Completed:
Step 19: 40% complete.
—airbrushed the railroad ties with MM Leather enamel and the rails and connectors with MM Burnt Iron.
—hand detailed the ties for the metal work that attaches the rails to the ties.
—placed ties for first two sections and their respective rails.
Total time today: 3 hours
Total time to date: 50 hours
Progress Pic:
Additional comments:
Threading the rails through the ties already in the embankment was very rough going… the tolerances are very tight and ended up having to use needle-nosed pliers to feed through the last few ties. May try threading the rails first and then placing the ties but that has some risk as the tie connection points aren’t all that strong…have to think about it first and try it verrrry carefully or I’ll be on the phone to Dragon again for more parts. [:P]
Weathering of the rails and the ties will be done once the entire rail section is complete. At this rate, that won’t happen for a couple days.
Day 11 Log: September 14, 2004
Errors Found: none
Steps completed:
–Continued working on Step 19 and building the rails for the Leopold to ride on. Installed a 2nd section of ties and rails and joined it up to the first section. Had some success with threading the ties onto the rails and then adjust them to fit the slots but the tension was too high once a few ties were in place and the rail would slip out of the guides. Tried this three different ways and no luck Ended up putting the ties in place and threading the rail through as with the first one. These rails went in much smoother, no pliers required, probably because of the pre-threading I’d already done. As I suspected, it’s taking about 2 hours to install one set of rails so I’m getting a section a day done working on the railroad… [:-^]
—A word of caution about the ties and the embankment slots. I learned this the hard way with the first tie and neglected to mention it in yesterday’s entry. Once you get the tie into the slot…it won’t come out. It takes a bit of pressure to get it to go in all the way, and once there, it stays. Only way to get it back out is to thread the rail through it and use the rail to lift it back out but this runs the huge risk of the rail slots on the ties bending or giving way completely in the process.
–Weathered the first set of ties installed yesterday with black pastel and a small sable brush. You can see the before/after in the progress pics. Still a long way to go before this road is finished.
Total time today: 2.5 hours
Total time to Date: 52.5 hours
Progress Pic:
Just an impressive build so bar Bill. It’s like watching a reality tv show. Just way cooler.
Maybe one of the cable channels should pick up on this idea…it could work on a Survivor/Apprentice type model I think. [:o)] Take a group of modelers, lock them in a house or on a deserted island for 6 weeks and tell them to build like maniacs…hey if Gilligan and the professor could turn coconuts into phones, it could work. [:D]
bill simply outstanding work so far. thanks for the updates on your build.
joe
Bill. It’s just absolutely poetry in motion, watching you put this all together. What a treat. semper fi, mike
Mike and Joe,
Glad you are enjoying the ride along with me! I’m enjoying this build immensely, so many different things to work on to bring it all together. It comes with a set of figures specifically designed for this kit as well and they are highly detailed, so more hours will go into them as well before she’s all wrapped up. [:D]
Day 12 Log: September 15, 2004
—I figured out by accident why they have the ties go into their respective slots in that zany pattern outlined earlier. I accidentally put a g2 in a g7 slot due to poor attention and mistaking the upside down writing of a 2 for a 7…pushed it in all the way (once in they don’t come out) before I realized the mistake. The impact hit home when I threaded the rails through. The misplaced tie had it’s rail holder out of line by about .5 mm…just enough to make the rail bow slightly as it passed through. Fortunately this happend right at a rail junction so I was able to correct it using the other rail and the rail joint halves.
Steps Completed:
—Completed Step 19 in terms of the construction of the railroad bed. Ended up with 7 extra ties and 1 set of extra rail joints, but that was to be expected since they give you 7 sprues with 6 ties and 1 set of joints but you only need 57 ties and 6 sets of joints.
—Weathering of the rails and remaining ties still needs to be completed.
—Discovered a neat way to cut the rails cleanly. I used a pin vise and drilled a hole in the center of the rail where the plastic was thin and then used the sprue cutters top and bottom. Only a small amount of sanding required to smooth it out and didn’t have to worry about stress cracking or a ragged end to begin with. The measurements they give for the final rails at 154mm seems a bit off…unless you want the rails extending off the end of the embankment (this looked strange to me and I ended up removing about 10mm off the ends so they looked clean on the ties).
Total time to date: 55.5 hours
Progress Pics:
Hopefully my replacement parts from Dragon will arrive this weekend so I can build the remaining ladder I need, secure down the gun mounts, and begin weathering the on the gray structures. Cross those fingers!
Can we make sure it is a nice tropical deserted island?? Ahh…sun, tropical drinks and model glue. Now THAT’S av Vacation. The build is looking great, by the wya
Thanks Jwest! It’s been a great ride so far…the end is starting to come into view now…unless that’s just a locomotive coming down the opposite track! [:O)]
Day 13 Log: September 16, 2004
Errors/Issues: None
Steps Completed:
—Completed weathering on the railroad ties. Am debating whether or not to go ahead and weather the rails themselves or leave as is. I’ll try out a little bit of drybrushing tomorrow and if it looks good, will do the rest. If not, will repaint the test section and leave as is. [:D]
Time today: 2 hours
Time to Date: 57.5 hours
Progress Pic:
Additional comments: I’m having real problems getting good pics now due to sheer size. My normal portrait area is designed for the usual 1/35 tanks and vehicles, but can’t accomodate this monster. Had to use the flash so everything looks lighter/shinier than it really is. Oh well…the limitations of indoor digital photography at work I guess. [:D]
The rails also appear in the photo to not be perfectly straight…I’m not sure if that’s a combination of the lighting/flash, the alignment of the track vs. the photo, or slight variation in the ties, or all three…When I look down the track length from one end, they look straight so I’m not going to worry about it that much… [;)]
Wbill, you are a modeling machine. I have been watching your progress and am amazed at the speed and accuracy in which you taclkle all of your projects. These forums surely give me alot to aspire to .
Hat’s off to you.
Thanks ted! I am thoroughly enjoying this build and it’s likely to be finished much sooner than I had originally thought it would be. I’m seriously considering entering it in the October DesertCon being held here locally but I’m not sure how I’d work out the transportation logistics for this monster… [:D]
This work really needs too make it to the Oct DesertCon Bill. I wonder if maybe you get a sponsor from a local business too assist you with logistical transportation of this traffic jam in the making? It’s just a thought! Take a couple of photographs and show it around. You might be surprised how some folks might want to help.(note). I can just see your local funeral home hauling it in one of their hearses. On the other hand it probably would be the safest way to move it. Think about it. semper fi, mike
Hmmm not a bad idea there mike…although it might look very strange if I roll up to the contest site in a hearse! (It’s being held in a methodist church event hall). [:D] The good news on transporting it is that even when completed, it can still be broken down into the track bed, the gun cradle, and the railroad carriages without too much difficulty.
Well Bill! sometimes my ideas just don’t quite meet the sensitivities of the surroundings. In this case the hearse idea might not be the way to go. You folks would probably be looking for a new place to exhibit your work in the future. semper fi, mike
bill i agree this has to make a contest appearance. it is an awesome site.
joe
Don’t forget the bikini clad native assistants serving us coconut milk with little umbrellas. Just a nice thought. [;)]
Bill, I lost the pool. I thought 50 might not be enough. The picture might not be accurate, but it looks like the top of the rails needs some shiney steel. Sorry if you did this already, just the pic looks as though it needs it, at least on my computer.
You are psychic eric! The last pic from yesterday showed only the weathering being done to the railroad ties. The first thing I tackled today was weathering the rails themselves. [tup] No one else entered the pool, so I guess I’ll keep the virtual dollar. [:D]
Day 14 Log: September 17, 2004:
Errors Issues: None
Steps Completed:
—Continued/Finished the weathering to the railroad bed by drybrushing MM Steel lightly on the rail tops and edges as well as the rail joints. Followed behind with black pastel to slightly dull the silver so that it retained the exposed metal look without being too shiny. Going off the local railroad references I pass by, it seems that the rails themselves don’t stay as shiny as opposed to the railcar wheels.
—Weathered the upperstructures on the SP engine housing and shell loading decks. Drybrushed with MM steel and again followed along behind with black pastels to create shadows on the deck grids as well as slightly dull the scratched/exposed steel.
Time today: 4 hours
Time to date: 61.5 hours
Progress Pics:
Weathering this beast is an unusual proposition but so far progressing well. The kit included a figure set so they will be added as well to further bring it to life. Extra parts have not arrived yet and I’m holding off mounting the ladders and railings until I have them all and can take care of them in one go. Tomorrow’s efforts will focus on continuing the weathering process and getting ready for the huge number of decals. [:0]
The weathering process on so large a piece of work has got to be pretty tedious. I think that one would have trouble just maintaining a consistency with so much area to weather. looking forward to seeing more. Keep up the tremendous job you’re doing Bill. semper fi, mike
Mike,
That’s kind of why I’m doing the weathering in sections. I keep referring back to the ones already completed as I do a new one in order to try and keep some consistency going while still having enough realistic variation over the whole thing. It’s tough…I take a lot of breaks in this process which makes it slow going but insures I don’t get in a big hurry and make a costly mistake, or at least I hope it does. [:D]
Day 15 Log: September 18, 2004:
Errors/Issues: None
Steps Completed:
–Continued the weathering process on the railroad carriages. Completed both front and rear using the MM Steel and black pastel combination. Sealed both up with Testors Dullcote as I’m now having to move them around quite a bit and keep finding traces of black pastel show up on my fingers at the worst moments… [:0]
—Added the kit-included copper safety chain to the shell loading deck. It was somewhat of a pain, not enough to qualify as an issue, but still a pain, because the chain links do not slip over the attachment points as indicated in the instructions. The links are too small to do this easily, but nothing a little CA and accelerator couldn’t handle.
—Began the weathering on the gun barrel and mount/elevation mechanisms. These are now completely weathered but still unsecured due to waiting on replacement parts from Dragon. This makes it particularly difficult to work on but I think it’s better to take care of it now while I still have some flexibility to it than trying to work with it locked down.
–Re-puttied and sanded the breech block joint area after examining it and discovering gap/seam still visible (sometimes it pays to let things sit for a while and come back to them with a critical eye!).
—Used the airbrush to repaint the breech and touch up some areas that had scuffed since the last paint application. Used up the remaining 1/2 bottle from the previous painting so that makes 4 bottles of Schwarzgray that have gone into this beast.
—Constructed the kit-included shells and canvas powder bags. Painted and weathered them. One shell and the bags will go on the shell cart with a figure pushing them, not sure what I will do with the other 3 shells provided, but will no doubt put them to good use. [:D]
Total Time today: 8 hours
Total time to date: 69.5
Progress Pics:
Additional Comments:
Weathering is taking longer than anticipated. I still have the gun cradle itself to weather and it has a lot of surface area to deal with. My intention is to finish the base weathering, apply a gloss coat to the cradle, add the decals, then gloss coat to seal and dull coat over that and then add weathering as needed. The figures on the shelf are starting to mock me, they know all too well why I’ve saved them for last… [B)]
As another note, the MM Steel is showing up in the pics as more pronounced than it actually is under normal lighting conditions. I use two 60W lamps for taking the pics and this lighting is somewhat harsher and the digital enhances the brighter look as a result.
Looks like you’ve been working on the railroad this weekend Bill! The weathering looks like it is coming along nicely. Just one question on the weathering process you use, When you use the MM steel and pastel black, are the two being mixed together or are you applying the paint then brushing the pastel over the still wet paint? I’m very very new to using pastels and don’t think I’ve quite got the jest of appying them yet. Seems I’ve read that sealing the pastels takes away from the weathered look? I don’t really want to get away from your building of this huge gun but the question ia one I’m trying to better understand. Better let you get back to your railroad it’s fantastic so far. semper fi, mike
