Original thread here… http://cs.finescale.com/fsm/modeling_subjects/f/2/t/159636.aspx ------------------------------------------------------ Some updates and work done on the engine bay. I’m not sure if I’ll add any more detail like wiring etc, it looks ok as it is.
Looking very sharp
Thanks, much appreciated!
nice job
Looks like you are off to a pretty good start. Just a note though, the Academy UH-60 kits are all 1/35, not 1/32.
An update, I wanted to add a couple of fire extinguishers and axes. So I grabbed this extinguisher from the 1070 tractor truck kit to make a cast. I’m using a pressure casting setup but the air escape lines need to be good for these small parts. I use oil based clay to seal up the mold. This approach took a while to work out, I don’t use the gear very often, but is good for large casts or small pieces like this.
This is the vacuum chamber I use to degas the silicon. The silcon expands to 4 times its size so for larger part this chamber is very useful.
I have some way out of date resin I’m using but it does the job. This stuff is normally white in colour.
I should have done this earlier but some how, like putting a ship in a bottle or something, I maneuvered the new parts into position. I also scratch built this green pack seen between the gunner seats, not sure what it is exactly. But the interior is starting to look busy and realistic looking.
Very nice
Thanks!
its nice to see another helo build . Its a very nice build
Great skills
Rick
I can only speak for US Blackhawks but the pack between the gunner’s seats is quite possibly a survival kit. It is also common for flyaway gear to be stowed in a kit bag between the seats as well. It is quite a useful space and all kinds of things get stowed there in addition to these.
Nice work so far! I really like this kit, I can only pick nits with it. There are a few things that can be easily tweaked but not really noticeable unless you know to look. I’ll have to not be such a stranger an follow this along. Let me know if you need any references, I don’t really have anything on the Aussie birds but info on the S-70 airframe is no problem.
