1/35 AH-1W Cobra questions
The AH-1Z does have a four-blade main rotor. It is known as the “Viper” and is fighting alongside the AH-1W SuperCobra.
Here is an article on wikipedia about the AH-1Z: http://en.wikipedia.org/wiki/AH-1Z
Wow, check that out. Looks considerably larger…there must be some other significant changes?
The AH-1Z is the latest version that is currently being fielded. It has a 4-blade main and tail rotor, larger wings with more weapons hardpoints, along with a lot of other upgrades.
In that pic it looks a whole lot meaner…Cobra on steroids? [:O]
The surgery to add the Cobra Company upgrade isn’t that bad. Sure you need to cut off the nose and cut the canopy but you don’t need to add the new area betweenb the engines (the new doghouse fairing with laser warning receivers isn’t needed as it was never incorporated except for on a few aircraft). Also, there shouldn’t be any surgery involved with adding the oil cooler shroud on the belly.
