Hello All, it has been quite a while since I posted a thread here, but here I am, This is going to be a Revell RF 4C front fuselage, being combined to a Tamiya F 4C. Why? The Revell offering is very mis-shaped and lacking decent detail the Tamiya has. I will be attempting to create RF 4C Tail # 65-0866 of the 12th TRS 460TRW at Tan Son Nhut, Vietnam in 1969. I am doing this to honor my friend retired USAF Pilot L Clark , and his Crew Chief D Dixon whom are technical advisors on this build. Clark flew this tail# and Dixon was CC. My bird will be “drawers down” so the camera bay will be detailed quite a bit…
Starting with the cuts made to both fuselages to be mated together, and to fit “seamless” intakes as well as the camera bay doors…
Viewfinder window cut out and clear styrene added
My best attempt at scratching together a KA-55 camera for the #3 station, dry fitted into place with a scratched “gyro” mount…
I made and opening for the right side photoflash compartment and may open the left as well as I found out after doing so that the left banks were used first, so it’s open up or scribe them on the other side. I made racks with 123 cartridges that were used in that era, everything is dry fitted the length of the carts needs to be made as well as additional detail
The Cutting Edge seamless suckers I have were a very big disappointment to say the least. Full of pinholes and wrong /missing panel lines , so rather than dealing with the large ledge the kit parts have , I ground them down paper thin and added the kit skins to them keeping the seamless look. Now I will need to rescribe and sand down all the raised panels on them.
Starting to get the camera bay internal detail going, added scratched door latches, viewfinder tube, rear bulkhead and there is a never ending amount of detail in this compartment
Holy cow Handi! Phreaking Phabulous! Just what we need in here. More Eph- phours. Nice detail and kitbashing! Tell me why Tamiya always stops short of kitting a whole line of a certain subject?? I’m building my own phrankenstein F-4D in 1/48 because I want one with recessed detail and don’t feel like scribing a whole kit yet. Great honor to your friends as well. Keep it up!
Thanks for the kind words All. I fell out of sight for a bit taking care of a parent with health issues. A sibling in town gives me the chance to do a quick update on my kitbash. Progress has been glacial at best, working in the middle of the night mostly…
So far my camera bay has come together, with ten pounds stuffed in a five pound bag, bulkheads, station 3 with KA 55 camera and gyro mount, viewfinder tube , ducting , wire bundles and forward control rack with various boxes are all stuffed inside. All of the inner works had to be scratch built.
Here is the rear main IP… scope with a dull foggy “turned off” look. I made the rest of the ip’s and panels with decals made from both the dash-one and graphics sent too me by the crew chief…
Here the front gear bay is taking shape…
And the missle rails are filled and doors added… a bit more work to do on this…
Well that’s all I have for now, hopefully soon I will be able to pick up the pace with this and on the rest of the Forum as well.
Thanks Everyone for the kind words… I finally finished the two MK 7 seats for the most part. I thought going the way of Brassin seats would be the way to go as the rail and “horses head” are the only ones with the correct dimensions of how they overhang the upper chute container, mistake…They are too tall and the seat bucket is too wide.
Here is the height difference between the Brassin and Avionix seats as I am using the Avionix resin set for the Cockpit tubs…
Rather than lower the floor and mess up the side panel height, I cut the rail and head off of the Brassin set and shortened them, then routered out the Avionix seats. The result looks good I guess. I suck painting belts, so off they went as well, the end result was achieved with a combo of tape and pe belts, and added wire and solder to the seat.
Great work here! Like, what would be the use of 1/32 scale if not for builds like this one? The ejection seats are looking beautiful! Good luck with your build and have a nice day
I hope things have straightened out for your some, it’s good to see you back.
Amazing job there, that’s one of the reasons I don’t do 1/32nd is that I almost feel like I have to superdetail things out like you’re doing- beautiful work!
Thanks everyone! It has been a while since I updated this build but progress has been made. New panel lines scribed in the vertical stabilizer, both kits fuselage parts fused together, intakes in, office finally figured out (1969 SEA configuration)and fitted into the fuselage, canopy rails and more correct looking glare shield scratched together, parts dry fitted… now just a matter of detailing wheel bays, aux air intakes, landing gears, canopies and so on…
Well it took a while but this one is finally done. some more of the mods made to the kit included, cutting the oversized aft vents on the Tamiya fuselage and replacing with graft piece from the Revell, added detail to the aux air intakes, added hydro lines-ect to the wheel bays, scratched together all the photo flash compartment detail and doors, all the detail inside the camera doors including the cameras and mounts, I also opened the latches on the doors for a more realistic open look. I added a set of Isradecals after painting and then put another layer of paint over the stencils to give a more true look of a camoed bird in SEA 1969. The burner cans and nozzles and inner pylons were made out of resin and given to me by the CC D Dixon. They are fantastic! I added adjustment screws to the pylons as well as stabilizing adjustment screws for the cl tank. The braces for the fins of the cl tank were scratched as well as the mount and fins. All of this was finished off with some RBF ribbons in places specified by the CC Handbook of the RF 4C…
This bird would not have turned out close to this without the help, encouragment and tech advice from D Dixon and L Clark, the two men this build is about. For their years of dedicated service , and friendship. Thanks again Guys.
Excellent work all around Handi! Every part and detail I see is well detailed and painted up perfectly. the pylons and fuel tanks look right on. I love the SEA camo recce Rhinos! This has been a great and professional build to follow!
