1/32 HK Gloster Meteor F.4
This was a commission build, the buyer though, did not want bare metal finish and wanted an “off white” colour as well as the diamonds on the fuselage roundel decals cut off. This is a great kit to build but would be better with detailed engines obviously. I would suggest AM decals though if you are building this, as the kit ones lift off backing paper in seconds of putting them in water, and are very fragile!
Kit- 1/32 HK Gloster Meteor F.4
Extras - BIG ED set
Paints - Main colour - Italeri Flat Light Gray (F.S.36495) mixed with a bit of Flat white around 85/15 mix.
  • Interior is Gunze interior green
    Other paints used- Tamiya, Vallejo, Gunze Mr. Metalizers.
    -Klear for clear gloss coats
    -Flory Dark Dirt wash
    -Vallejo Satin Varnish for final coat.
That is a stunning job!
Your skills are fantastic! Great plane build.
toshi
