So, my latest adventure into the wonderful hobby of model building.
The new Airfix 1:24 F6F-5 Hellcat:
Going to be doing it in the “Operation SUNFISH” scheme, just because I think the other schemes look less interesting, just being blue [;)]
As usual, I just dived straight in without thought of photos and have only now thought to take any! This is being built OTB with the exception of the guns. Bought a replacement brass set (tho can’t remember who from!)
The cockpit, fuse and wings went together without many problems. Only issue I faced was when I joined the fuse and wings together and found the fuse was slightly larger than the gap in the wings! No doubt an oversight on my part, but nothing some sanding couldn’t fix.
Bit of overspray in the cockpit where I got carried away with the rattle can
Have now just finished up the engine, added the extra detail with 0.7mm copper wire as suggested in the intructions…question, what colour should the copper hoses be? Black?? Thinking I might leave it copper colour to give a bit of ‘character’.
Thats it for now…more to come…thinking I have lots of ‘free time’ due to the current corona situation
Stay safe out there.
Man, that’s looking really good!
So, another day spent on the engine, finally got all the exhausts on. This is really fiddly, especially since the ignition wires have been added (I think if these had not been added the exhausts would have been much easier). By trial and error I found the easiest way was to fit each ‘pack’ of exhausts in pieces and then glue together once I got them in place. The first ‘set’ I assembled the pieces together (some of the exhausts are 2 piece) and then had a devil of a time to get them in place!
Anyways, here’s how she looks just now…
As always, comments and critique welcome.
That’s looking good. You’re doing some nice work. I’m stuck on the starboard wing. It’s amazing how so many parts can fit together so precisely in one half of an assembly and the other half doesn’t want to fit at all. Lol. On the bright side, the port wing fits fairly well. Like you, I have some extra time now.
More progress today, got the engine and other related parts fitted, outer panels to follow after dirtying the engine up a bit more. Undecided on whether to leave some or all of the panels off else I’m gonna end up covering a beautiful (in my opinion) engine.
Comments / critique always welcome…it’s how we improve.
Can anyone suggest the best glue (type) to enable me to ‘temporarily glue’ the engine panels in place for paining, but be able to remove some/all the panels afterwards without damaging the underlying paint. Thanks
I’ve used Microscale Liquitape before. It was ok but not perfect. You apply it to one side and allow it to dry then put the parts together. Sometimes it was too sticky and made it difficult to get the parts apart and sometimes the little blob of glue would transfer to the other part. I seem to remember it leaving a residue and being difficult to remove if you didn’t want to use it anymore. It’s been a long time since I used it though and I may not have used it correctly.
So, I finally took the plunge with this model and have tried pre-shading.
For those brave souls who have gone before me could I please have a little feedback on how it’s looking…I think it looks ok (but the wife thinks it doesn’t…but what does she know…lol) If figure if it’s not so good then I can just go heavier and cover it all up!
Generally it looks good.
I would not have treated the control surfaces that way, as they were all fabric covered except for the short flaps on the stub wings. Or maybe go the other way and post shade the spaces in between the ribs.
So, I have continued some more in my first ever attempt at pre-shading. Following on from advise in a nother thread I have sprayed the grey, and with great care in masking, started on the second color. Think it looks reasonably OK…what do you guys think?
Looks pretty darn good to me. I’d never know it’s your first try at this if you hadn’t said so. I like this camo. Good choice.
Love the engine! Agree with you I wouldn’t want to cover it up.
Did you find a way to hold those panels on? I ve used the liquid tape before with similar results, sometimes it sticks too well. I have used blue tack, poster putty before. It works ok if you aren’t turning the model upside down. A little risky in that case.
in terms of preshading, my observation has been that the camera doesn’t pick up the contrast real well. If that’s the case with your pics Iwould think the underside is a tad on the light side. The top looks good to my eye. All said in the interest of sharing opinions. Weathering tends to be not only an eye of the beholder thing in my book, but also dependent on real pictures that you might be using. Sometimes people don’t like the look but the modeler did a stellar job of simulating a real plane or ship or car. Hope this helps [:)]
So, she is finally wearing her colors. Gonna pop her in the airing cupboard for the night, then tomorrow she will get her clear-coat…Alclad II Klear Kote Gloss ALC-310.
Looking at photos just reminded me that there is a little more white paintwork to be done on the front cowling…just realised! Best not forget tomorrow.
@TheMongoose, thanks for the kind words. Pannels have been temp held on with liquid mask, seems to do the trick. As regards using photos, I tend just do things that look about right to my eye. I greatly admire people who use many references to produce ‘authentic’ models…but that’s just not my thing. Maybe one day [^o)]
Outstanding Steve. I think your preshading looks quite good. Those MRP paints certainly spray nice, but I hate how glossy they are.
Thanks Lawdog, high praise coming from you, I have been mightily impressed by your work.
I agree with you on the MRP paints, they are too glossy…but, they most certainly spray well straight out of the bottle (used the MRP for the underside and green top side). I found them to be much more ‘controlable’ WRT the underlying pre-shade. However, a clear coat seems to have evened things out. Just started this evening on the decals, no photos yet. Another clear coat after decals then a little more weathering and then gonna try my first ever car! Just like many, many others…I find I have a lot of time on my hands just now as we/I am house-bound due to the current situation.
I am pretty happy with how my first attempt at pre-shading went, got a little ‘heavy-handed’ in a few spots, but hey…this is a learning process. If you don’t try then you will never learn
In hindsight, maybe I should have tried this on a cheap model first instead of ths one which ran at about £130 (more like £150 with paint!)
So, here she is…all decaled up and painted. Still needs another clear coat to seal the decals and then some weathering and then the final assembly of flaps, undercarriage, panels etc.
Appreciate any final comments before I seal this up completely.
One question, I got carried away in the early steps and drilled the holes for the 5 inch HVAR’s (3 per side), but now when I find myself at the end I note that the HVAR’s do not seem to appear on the FAA scheme I am doing! Does any kind soul know if the FAA version would ever have had these HVAR’s or am I going to have to fill the holes back up?? Thanksin advance for any info.
Oh that looks pretty! Love it.
Wow this thing is turning out great.I really have to get me one of these.
Thanks Mongoose
Lawdog…thanks for your kind words.The kit goes together very nicely and I’ve only needed a little bit of filler. That said, you do have to follow the instructions carefully…very carefully! The only real issue I had was making the two fuse halves join, the cockpit was slightly too wide so a little filling was needed to make it a little ‘not-so-wide’
My kit is OTB with the exception of some brass gun barrels, tho to be honest, now everything is closed up I wish I hadn’t bothered and just gone with the kit ones, guess it depends if you want to leave the ammo covers off or not.
A fruitful weekend, got this finished up [:D]
All the ‘bits’n’bobs’ got added, flaps, undercarriage, ordinance, antennas and pitot (have lean’t that they get added very last thing else I always end up snapping them off no matter how careful I try to be!)
Overall, very happy with the way it’s turned out. Built up easily with no major fit issues, very little filler was used throughout the build and personnally, I’m very happy with my first pre-shade model.
Enjoy:
As always, comments and critique most welcome, it’s how we know if what we are doing is good or not (and where to improve)
