1/200th Scale 40mm Twin Bofors - from where?
Greetings!
If anyone knows where I can find 40mm Twin Bofors cannon for a Sterling U.S.S. Missouri, please e-mail me at theoracle7@aol.com - I need to find good copies of this and the other equipment to make this old tub presentable for a VFW display!
Best Wishes and Happy Modelling!
Drew Pooters
Middlebury, IN
theoracle7@aol.com[8D]
Drew,
You won’t find much in 1/200 precisely, but you can easily use 1/192 scale, which is a standard scale…
Go to www.floatingdrydock.com, and look at HR Fittings in 1/192, they have EVERYTHING you’ll need for this particular model. I refurbished a partially built Sterling Missouri as a New Jersey a few years back, and the client spent a ton of money on the fittings…
http://www.floatingdrydock.com/fittings.htm#192
Hope that helps,
Jeff
