Hi fellows… [:)]
This project was started in mid 2008 but was set aside while skills were honed enough to complete it, so I’ll begin with the WIP photos, then pick up where I am this day:
I decided to begin the process by working-up the wing. Since it will be displayed as if it’s about to land, everything will be hanging out, so I dissected the flap & spoiler sections…
I used sanded spru rods to reinforce the Flap Guides…
The rods were heated and bent to the correct angle and glued into the groves, then before it set, the final positioning was done…
Puddied the seams and it is now before the fan getting dry…
I boxed in & braced the areas inside the Slat openings and between the upper & lower trailing edge wing surfaces (flap opening), scratched landing lights, then assembled the wing halves and flexed it…
I also sanded, shaped, and trimmed out the Slats and Kruger Flap, so they’ll be ready and waiting when I get to that step!
Building the inboard flap section using the “Wire Brace” technique, which sure makes it all go together easier and look more like the real thing.
Here’s the assembled slotted flaps, dry-fitted to the flap guides…
LE Slats - made from the pieces extracted from the lower wing half…
…dry-fitting the structurally complete flap-job…
The Captain’s/First Officer’s expression has St. Maarten written all over it…
June 2008 - - - Feb 5 2010
Back at it again here…
Resurrected the St. Maarten diorama that was set aside in 2008; today I took it from the box, cleaned it up, re-painted the blue and applied the decals… (the wing is dry-fitted in place)
I got the wing attached and cleaned up, but too pooped to get into the landing gears tonight…
More to come… [:)]
Take care,
Frank
