1/16 M26 Pershing Build - Part 3
Hello All,
It’s that time of week again, ready for Part 3…
Links to the images are provided due to the fact that the FSM forums do not support this form of picture embedding. If you want to see the same post but with all the pictures in line with the text, go to: http://www.armorama.com/modules.php?op=modload&name=PostBoard&file=index&req=viewtopic&topic_id=25989&page=1
p.s If you don’t see any pictures at the links, come back at a latter time, there might be bandwidth problems with the photo server.
http://images.fotopic.net/?id=2817456
Here’s a shot of the metal tracks I ordered from BackYard Armor (http://www.backyardarmor.com/). These are Kenny Kong tracks of the highest quality, made with Zinc alloy I believe… don’t quote me on that.
http://images.fotopic.net/?id=2817457
If you can afford them, I completely recommend it, they are just amazing to behold. They weight nearly 3 lbs!!! The tracks usually come with a few spares and extra pins with end caps. There are enough spares to replace the plastic spare track links that are mounted on the turret if you so wish.
http://images.fotopic.net/?id=2817458
Assembly is quite easy, here’s a sample of each link. Yes, they do come pre-assembled, but sometimes shipping will undo many of the links, if you decide to blacken the tracks (I’ll talk more about this in the next build update), wait till after you have done so before applying a bit of CA to each link end cap.
http://images.fotopic.net/?id=2817459
If you do go for the tracks remember that you will be limited in building a Korean version of the pershing, as far as I know this type of track only showed up on the Korean variants.
http://images.fotopic.net/?id=2817460
Here’s a shot of the metal tracks against the kit included vinyl ones.
http://images.fotopic.net/?id=2817501
It’s time to work on the back, yes I know I’m skipping steps here, but it’s easier to do the modifications/additions to the back of the hull without all the heavy gears and motors installed.
http://images.fotopic.net/?id=2817503
I thought I’d would go ahead and replace the plastic tow cable and brackets. It’s very easy to build the brackets yourself. I’ve seen reference shots where the brackets were simply steel angle brackets welded to the hull, and I’ve seen shots where the brackets had a slightly molded curve around the tow cable. I’m not a rivet counter, so here’s a bit of artistic expression, this bracket is a prototype, the real ones will be slightly narrower.
http://images.fotopic.net/?id=2817502
Here are some of the tools I used to rebuild the tow cable brackets, a piece of brass angle, shaping pliers, a razor saw and a PE cutter.
http://images.fotopic.net/?id=3061827
Here’s a shot of the replacement tow cable up against the plastic molded one in the kit. The new cable is made from 1/16 steel twine cable (It’s about 1.58 mm just a tad larger than the actual correct scale size of 1.5 mm), pick it up in any hardware Store for pennies a foot. If you buy the same cable in a Hobby shop it will cost you 10 - 30 times the price!! You’d be surprised how many great things you can find in hardware stores for a fraction of the Hobby price. Cut the ends of the cable on a diagonal, this will allow you to easily fit them into the tow hooks.
http://images.fotopic.net/?id=3061836
Here’s the kit included tow hooks and a shot of the completed brackets, as you can see the tow hooks were meant to be cemented to the back of the hull on the flat side. First you will need to gently drill through the back end a bit to make room for the cable to be inserted, after, you will need to add a small bit of styrene sheet and reshape the flat part of the hook. There is a German company that provides a metal version of these tow hooks (I believe the place is AFV-model: http://www.afv-model.com/, unfortunately I’ve heard many negatives things about this company from North American customers, buy from them at your own risk).
If you missed Part 2 from last week, here’s the link: http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=15677
See ya in two weeks (out of town on business next week), same BAT time, same BAT channel…
BUDA [:)]
Those are some serious tracks, Buda! Those represent the rubber-padded tracks…does Mr. Kong also offer the all-steel tracks (like the Tamiya tracks represent)?
Nice work on the cables and clamps.
Looking forward to part four!
buda
Am new at this but this may help www.fragarmor.org/home.htm in gallery-g they have some good pictures of Pershing tool boxs that a member did they look great. Also www.nwsl.com it is a train site they have metric nuts screws and taps and dies page 7 of the catlog will give a list 2.0x18mm 6ea .95 or a bag of 100 $8.50 have fun with your Pershing it is a great tank a nd a lot of fun to build
Wow, those tracks are some serious hardware. Can’t wait to see how you end up painting those.
Keep up the interesting posts. It’s really fun watching you build this up!
Looks Great Buda! I loved the way the sound from Backyard Armor came on right in the middle of my **$%% STUDY HALL! (not).
Oh well, worth a laugh. I guess I’ll never find out about their products until I want to listen to the barrage, eh?
Ron
Excellent Buda. Thanks for the very detailed progress pictures.
mark956
J-Hulk
Unfortunately, these are the only type of pershing tracks he makes (He originally took a survey of everyone interested, and they all wanted this variant of the tracks). I do know that there is a European company that makes the other two variants (The WWII variant, and the one you spoke of), but for the life of me, I can’t remember the outfit’s name. Either way, those tracks were in the 280 Euro range, way to bloody expensive, they were also made out of nickel.
redlongarm
Thanks for the links redlongarm and welcome to the forum. You know, I must have been to the fragarmor site several dozen times and I never saw that pershing… thanks for pointing it out.
zokissima
I’m actually first going to blacken them, then apply a bit of paint and rust, then take them out for a test run on pavement for weathering, I’ll post the whole process in an upcoming build update.
Poniatowski
LOL, ya, I know what you mean, first time I went to that site, I had my speakers on high from just finishing a game in Bf1942, needless to say, I almost cr@apped my pants… LOL
mark956
My pleasure. [:D]
BUDA
BUDA,
That is one serious beast you are building there (and it’s looking fantastic)
Keep the progress pics coming!
Hey Buda,
Awesome job! Where did you get your model from…was it Backyard Armor? I was at their site today and they have some great stuff. I especially like the ‘Easy Eight’ conversion thats now out for the Tamiya 1/16 Sherman. Keep up the good work.
Looking great!
Can’t wait to see the finished product
Thanks for the comments guys!!
64condors
I picked this kit up last year at Military Hobbies, if I’d had know about BackYard Armor then I might have bought the kit there (Although the Canadian dollar last year sucked rocks). I have ordered a few things from BackYard Armor (waiting on a set of Tiger 1 tracks to arrive), and have been satisfied each time. I’m also looking forward to picking up there new suspension kit for my Tiger 1 (Here’s the site of the guy who makes them : http://www.wecohe.de/, I hope BackYard Armor starts offering more of his things, he’s got a lot of cool stuff that a lot of R/C’ers here would gobble up.)
Yep, the easy eight conversion kit looks great, If I ever get around to picking up a sherman, this kit will definitely be at the top of the list (ShermanFirefly you should check it out, I think you’ll love it http://www.backyardarmor.com/).
Thanks
BUDA
Hey Buda,
Thanks for the reply. I got an email from BYA and they told me that more upgrade stuff is coming in about a month (They have a email-newsletter for updates that goes out everytime a new product release is coming…if you want to get it you can sign-up at their site). Also they told me that Wecohe is their design partner in Germany and have been working together for awhile now…with these two guys working together I can only see great things coming. I also took the plunge today and orded the Easy Eight & Sherman kit and should have them both in about 2 weeks so I’ll give you an update when it arrives. I really can’t wait to see the decal sheet to do the 5 versions[:D]!
Thanks, 64
64condors, excellent update, I hope BYA starts selling that Jagdtiger conversion kit, that would definitly be a winner…
Can’t wait to see hear back from you about the Sherman conversion kit.
Thanks
BUDA
