I just received Revell’s 1/144 Launch Tower & Space Shuttle kit (I think a good deal off eBay for $60) The box photo is a night shot showing parts in grey, red and greenish blue. However, all the photos I see on the internet the entire structure is grey.
I am wondering if anybody has built this kit, and if so, did you use colors or just painted everything grey. I lean more towards looking good as opposed to accuracy so I am concerned with how it will look in scale with so much grey.
Any input would help.
Gary
I painted mine pretty much all Walmart primer grey.
The area inside the “garage” where the shuttle is serviced I painted white. Also the smaller section of scaffolding to the left of the “garage” (when you are looking at the front), the pole that connects the “garage” section to the launch tower, and the big lightning rod on top of the launch tower I also painted white.
I looked at tons of photos. The only parts that consistently looked white were the “garage” and the lightning rod. The other white parts were either repainted or it was a trick of the light that made them look grey.
Also the walls in the center of the launch tower were definitely either red or grey. I suspect the red must have been the color when it was first built as newer photos show it the same grey as the rest of the tower. I built this model when it first came out and I reburbished it several months ago. I originally painted this section red.
I left that section red and painted those other parts white just for the exact reason you mentioned about not having an all grey boring looking complex.
I just picked this up at my FLHS, and I have a paint question on the shuttle itself. The instructions show several different paint configurations on the wings, and two different versions of the side of the shuttle. The primary difference is the border between color ‘L’ and color ‘P’. I go to look at the color chart, and ‘L’ is matt white #5. Then I look at ‘P’ - matt white #5. I presume one of these is wrong, but which one? I even looked up and down the various translations of each color and there’s no difference in any language. What is the correct second color?
